Understanding C++ Constructors | Homework Question
  • Context: Comp Sci
  • Thread starter Thread starter AKJ1
    C++
2 replies · 2K views
AKJ1
1. Homework Statement
In the third constructor in the second snippet of code, I keep getting a compiler warning that hours, milli, seconds, and hours is not initialized in the constructor. Should I just set them equal to zero within that constructor? I have never worked with multiple constructors before, so if something looks really off, please let me know. Thanks!
edit - I don't know why some things are showing up with a and in the code
2. Homework Equations
Code:
//.h file
#ifndef TIME_H_
#define TIME_H_
#include <iostream>
#include <string>
usingnamespace std;
* Time class
* The Time class contains time as hours:minutes:seconds:milliseconds (AM/PM).
class Time
public:
* Constructor with zero values
    Time();
    * Constructors with arguments
    Time(long time);
    Time(int hours, int minutes, int seconds, int milli);
    * Deconstructor
    virtual~Time();
    * Return time as a long value representing time in milliseconds
   long asLong() const;
    * Display as a string in the format hours:minutes:seconds:milliseconds.
    * For example 1:45:30:56 PM
    * The time is displayed as 24 hours if the 24 hour flag is set true.
    std::string toString() const;
    * Enable/disable 24 hour time display
    void set24Hour(bool value);
    * Return true if 24 hour time display is enabled
    bool is24Hour() const;
private:
    int hours;
    int minutes;
    int seconds;
    int milli;
    long time;
    * Private members go here
#endif/* TIME_H_ */
Code:
* Time.cpp
#include "Time.h"
Time::Time()
    hours=0;
    minutes=0;
    seconds=0;
    milli=0;
    time=0;
Time::Time(int hr, int min, int sec, int mil)
    hours = hr;
    minutes = min;
    seconds = sec;
    milli = mil;
    time = 0;
Time::Time(long tm)
    time = tm;
Time::~Time()
Set it to whatever is reasonable for your class. If zero is a good choice, set them to zero.
The [b] are probably some copied syntaxhighlighting, but those codes are not supported in code tags here.
mfb said:
The are probably some copied syntaxhighlighting, but those codes are not supported in code tags here.
I removed them...
