Understanding Differential Equations
1 reply · 1K views
BOAS
Hello,
these are the first differential equations I've tried to solve...
Find the general solution of the following differential equations. In each case if
y = 2 when x = 1 find y when x = 3.
[itex]2x \frac{dy}{dx} = 3[/itex]
[itex]\frac{dy}{dx} = \frac{3}{2x}[/itex]
[itex]dy = (\frac{3}{2x}) dx[/itex]
[itex]\int dy = \int (\frac{3}{2x}) dx[/itex]
[itex]y = \frac{3}{2}ln|x| + c[/itex]
Firstly, is this correct and secondly, the question says that when y = 2, x = 1 but ln(1) = 0 so I don't see how this can be true. Or have I just found out that my constant of integration, c = 2?
Thanks for any help you can give!
BOAS
BOAS
I think you've just found the value of your constant of integration!
If you have solved a diff equ, you can always check your answer by diferentiating it and putting it back in the original equation. It's often worth doing if you're not sure.
