Understanding Endpoints & Overestimation/Underestimation of a Function
  • Thread starter Thread starter phillyolly
    Integrals
2 replies · 2K views
phillyolly
I am just seeking some clarification.
Can one tell me the difference between right and left endpoints when drawing a function and estimating its area with these endpoints? And how are they connected to underestimation and overestimation?
If you can draw graphs and point out which ones are over/underestimated, and which have left/right endpoints, it will be very helpful.
Thanks a lot.
The left endpoint is on the left.
Draw a strait line to the right endpoint. What do see?
You are given a function f(x) on an interval [a,b]. To estimate the value of
[tex]\int_a^b f(x)\ dx[/tex]
you make a partition of the interval:
[tex]a = x_0 < x_1, ... ,< x_n = b[/tex]
and pick points ci in [xi-1,xi] for i = 1..n. You then approximate the integral with rectangles of height f(ci) on each subinterval:
[tex]\sum_{i=1}^n f(c_i)\Delta x_i[/tex]
If you pick the ci on the left of its subinterval [xi-1,xi] then ci=xi-1 and if you pick it on the right of its subinterval, then ci = xi.
If f is an increasing function its value will increase as x moves to the right. Using the left end point and drawing the approximating rectangle, you can see that the rectangles always underestimate the area under the curve, but if f is decreasing, just the opposite happens and the area of the rectangle overestimates the area under the curve.
Surely your text has pictures of this.
