Understanding Integrals and the Importance of Constants
The discussion centers on solving the differential equation for charge q(t) in an RC series circuit with a variable resistor, where resistance is defined as R = a + bt. Participants confirm that capacitance C is a constant, dependent on the physical characteristics of the capacitor. The solution involves rewriting the equation in standard form, finding the integrating factor, and evaluating the integral with appropriate limits. Key points include the importance of treating the variable t correctly within integrals and the simplification of expressions during integration.
  • Understanding of differential equations, specifically first-order linear equations.
  • Familiarity with the concept of integrating factors in solving differential equations.
  • Knowledge of capacitor behavior in RC circuits, including the role of capacitance.
  • Basic integration techniques and the treatment of dummy variables in integrals.
  • Study the method of integrating factors in detail for solving linear differential equations.
  • Learn about the physical principles governing capacitors and their capacitance values.
  • Explore advanced integration techniques, including substitution and integration by parts.
  • Review the implications of variable limits in definite integrals and their applications in physics.
Students and professionals in electrical engineering, physics, and mathematics who are working on circuit analysis, differential equations, and integration techniques.
keyermoond
Suppose an RC series circuit has a variable resistor. If the resistance at time t is given by by R = a + bt, where a and b are known positive constants then the charge q(t) on the capacitor satisfies
(a+bt) q' + (1/C)q = V
where V is some constant. Also q(0) = q_0
Find q(t) as an explicit function of t.
Now I have obtained the answer, however my main question is: am I allowed to treat C (capacitance) as a constant in this equation. It doesn't specify in the question, but to my knowledge (unless I am wrong of course) capacitance is a constant value and only depends on material and physical parameters of the capacitor itself (how it is build).
If I can't treat C as a constant then I believe there is no way to evaluate the integral in integrating factor and I'd have to leave it as it is.
Process is simple from there, I rewrite the equation in standart form, find the integrating factor and obtain a formula for q(t), evaluate an integration constant with q(0) = q_0 and obtain the overall solution q(t).
The answer looks quite frightening btw
3. My solution:
attached pdf file
The capacitance must be constant during the all process, which just depends on its material and geometric shape, as what you say above,
Is there some reason you're not simplifying ##\frac{(a+bt)^k}{a+bt}## to ##(a+bt)^{k-1}## and integrating the righthand side? Also, the ##t## in the integral is a dummy variable, so it's not correct to set it to 0.
That's what my prof does. By setting it from 0 to t, we ensure evaluated integral is equal to the true value with t as a variable, how would setting it to something arbitary as t_o (I'm assuming that's what you mean)be any better? My understanding of it is that we need to choose some "convenient" interval, what's wrong with 0 to t?
And thank you for pointing out I can actually simplify it further, I completely missed that.
What I'm saying is you can't do something like this:
$$\int (a+bt)^2\,dt = \int a\,dt$$ by claiming you're setting ##t=0##. The ##t## inside the integral isn't the same ##t## that appears elsewhere.
I see what you mean, my mistake, thank you for pointing it out. I see holes in my knowledge about understanding of basic integration now, will have to fill them in :)
