Understanding Limits in Calculus: A Challenge for Differentiation
  • Thread starter Thread starter 939
    Limit
The discussion revolves around a limit problem in calculus involving the function y = x^2 - 2x. The specific limit to evaluate is lim x->2 ((f(x) - f(1))/(x-1)), which has led to confusion regarding the appropriate method for finding the limit and the interpretation of the problem statement.
  • Participants explore whether to substitute values directly into the limit expression or to apply differentiation. There is a discussion about the implications of using the derivative versus direct substitution, particularly in relation to the slope of secant and tangent lines.
Participants are actively questioning the problem's setup and the definitions involved. Some suggest that the problem may contain a typo regarding the limit's variable, while others clarify the distinction between evaluating the limit and finding the derivative. There is no explicit consensus, but various interpretations and approaches are being explored.
There is uncertainty regarding the definition of f(x) and whether it is correctly stated in the problem. Additionally, some participants express doubt about the relevance of the limit as x approaches 2, suggesting it may not be as instructive as other limits.
939
I am not sure what is meant by this question:
for y = x^2 - 2x,
find
for y = x^2 - 2x,
find
Normally to find the limit here I would just find the derivative, but this: find
lim x->2 ((f(x) - f(1))/(x-1)) confuses me. Do you simply find f(2), f(1) and substitute them in?
Yes. Since the denominator is finite and nonzero in the limit, you can just substitute in the x value.
(Are you sure the question is right?)
Yes, that is the question. My only question is why not merely take the derivative and find the limit at x = 2 that way? It gives a different answer...
for y = x^2 - 2x,
find
There should be a definition for f(x) somewhere. It's probably intended that f(x) = x2 - 2x, but it should be stated.
No. That's not what you're supposed to do.
If you evaluate [f(2) - f(1)]/(2 - 1), what you get is the slope of the secant line between the points (1, f(1)) and (2, f(2)). By taking the limit in your problem, you're getting the slope of the tangent line at (2, f(2)).
Possibly you already know how to find the derivative of a polynomial like the one in this problem. That's not the point of this problem, though - the purpose is to have you find the slope of the tangent line at a particular point using the definition of the derivative at a point.
for y = x^2 - 2x,
find
for y = x^2 - 2x,
find
Are you sure that isn't supposed to be ##x\to 1## and you haven't overlooked a typo?
I don't think so; not if the problem is stated correctly. In that case you are getting the slope of the secant line between (1, f(1)) and (2, f(2)). I doubt the problem is stated correctly.
Because you are not dividing [f(x) - f(2)] by (x-2).
As Ray V indicates, the derivative method is specifically for the case where the numerator and denominator both tend to zero in the limit. If the problem is stated correctly, they don't do that here, so just substituting in the values is the right way.
More generally, you keep taking derivatives until you get an answer that's not 0/0.
E.g. ##\lim_{x\rightarrow 0} \frac{x^2}{1-\cos x}##.
Try substituting x = 0, get 0/0, no good.
Differentiate numerator and denominator: ##\lim_{x\rightarrow 0} \frac{2x}{\sin x}##.
Try substituting x = 0, get 0/0 again, still no good.
Differentiate numerator and denominator a second time: ##\lim_{x\rightarrow 0} \frac{2}{\cos x}##.
Try substituting x = 0, get 2/1, solved.
Thanks to you and everyone!
There is one error on the question: it should read for f(x) = x^2 - 2x, for "for y".
Just checking... you do realize that Mark44's response was contradicted by the other three responders, yes? (I suspect Mark read what we all expected the question to say, not what it actually says.)
Yes, I must have seen it as x approaching 1. The problem isn't very interesting if the limit is as x --> 2.
yes, but you also have to substitute 2 for x in the denominator-- x itself is a function of x.
... unless it's designed to catch people who automatically apply differentiation :wink:
  • · Replies 18 ·
