Understanding Local and Nonlocal Operators in Quantum Field Theory
  • Level: Graduate
  • Thread starter Thread starter MathematicalPhysicist
    Operator Qft
167 replies · 15K views
I am reading the claymath problem here:
http://claymath.org/sites/default/files/yangmills.pdf
on page 6, in the comments (section 5), they call a local operator to be an operator that satisifies:
##\mathcal{O}(\vec{x})=e^{-i\vec{P}\cdot \vec{x}}\mathcal{O}e^{i\vec{P}\cdot \vec{x}}## where ##\langle \Omega,\mathcal{O}\Omega\rangle## where ##\Omega## is a vacuum vector.
My question is in that case how would a nonlocal operator look like?
If I remember correctly ##\exp(-iP\cdot x)## is the translation operator.
https://physics.stackexchange.com/questions/27087/a-question-from-ticcatis-red-qft-textbook
Demystifier said:
E.g. something like ##O(x)O(y)##.
What?
How do you define a nonlocal operator? i.e ##O(\vec{x}):=?##.
MathematicalPhysicist said:
What?
You missed the point. ##O(x)## and ##O(y)## are local operators. Their product ##O(x)O(y)## isn't.
Another example. Let ##O(y)## be a local operator and let ##f(x,y)## be some function. Then
$$A(x)=\int_{-\infty}^{\infty} dy \, f(x,y) O(y)$$
is not a local operator, unless ##f(x,y)=f(x-y)##.
I don't think that is what he is looking for, because the product is not a map from the spacetime, but from two copies.
Leaving aside how the integral is defined, or if it even makes any sense, why is this non-local? The article says that a quantum field or a local quantum field operator is an operator valued distribution defined on the spacetime, that satisfies some axioms. They don't give the axioms, but I assume they are standard. Which axioms are not satisfied by this integral?
I think the axioms are the ones which are described in the papers by Osterwalder and Schrader, here:
K. Osterwalder and R. Schrader,Axioms for Euclidean Green’s functions, Comm. Math.Phys.31(1973), 83–112, and Comm. Math. Phys.42(1975), 281–305.
I once asked a few questions about this paper in overflow, here:
https://physicsoverflow.org/32749/axioms-for-euclidean-greens-functionss-paper-3
@Demystifier then what is the definition of a local operator?
I thought it was the one which I quoted, i.e:
##\mathcal{O}(\vec{x})=e^{-i\vec{P}\cdot \vec{x}}\mathcal{O}e^{i\vec{P}\cdot \vec{x}}## where ##\langle \Omega,\mathcal{O}\Omega\rangle=0## where ##\Omega## is a vacuum vector.
I gave two operators that depend on ##x## but do not satisfy the definition of local operator that you wrote. Hence they are not local operators. I though that's what you wanted, an example of an operator that is not local.
Maybe, that's why I gave the second example.
##A(x)\neq e^{-ipx}A(0)e^{ipx}##.
Wait a minute, so ##O(x)=e^{-ipx}Oe^{ipx}## and ##O(y) = e^{-ipy}Oe^{ipy}##
so ##O(x,y)=O(x)O(y)## doesn't satisfy: ##O(x,y)=e^{-ip(x+y)}Oe^{ip(x+y)}## since ##O(x)O(y) = e^{-ipx}Oe^{ipx}e^{-ipy}Oe^{ipy}##
Ok that's answer my question, thanks.
I am still not sure about this. What are the axioms? Is being of the form ##O(x)=e^{-ipx}Oe^{ipx}## one of the axioms, or is it a consequence of the axioms? Also the product ##O(x)O(y)## doesn't seem to be an operator at all, let alone nonlocal.
Why?
Let ##|v\rangle## be a vector in a vector space (not necessarily Hilbert space) ##V##. If ##O(y)## is an operator, then ##|v'\rangle=O(y)|v\rangle## is in ##V##. Hence ##|v''\rangle=O(x)|v'\rangle=O(x)O(y)|v\rangle## is also in ##V##. As far I can see, this shows that ##O(x)O(y)## is an operator.
Demystifier said:
Why?
I am following the article. They define a local field operator to be an operator valued distribution on spacetime, that satisfies some axioms. In other words for each spacetime point ##x## you have an operator valued distribution ##O(x)##, that satisfies some axioms. To be a nonlocal operator would mean to not satisfy some of the axioms. The object ##O(x)O(y)## is not a map from spacetime to operator valued distributions. The proper multiplication is ##O_1(x)O_2(x)##. Here is an analogy. A continuous function is a map from real numbers to real numbers usually denoted by ##f(x)##, that satisfies some conditions. An example of noncontinuous function wouldn't be ##f(x)f(y)##, it is not even a function of one variable.
What if ##y## is treated as a constant, say ##y=7##? Is ##f(x)f(7)## a function of one variable?
Yes, and?
But ##O(x) O(y)## is an operator product, which is (only formally though) well defined, but it's not local, because the translation operator doesn't act on it in the way as defined above.
Demystifier said:
Then ##f(x)f(y)## can be interpreted as a function of one variable ##x##.
How?!
But the result is not a map from spacetime to...
Demystifier said:
By using ##y=7##.
Then it is not ##f(x)f(y)## it is ##cf(x)##, where ##c## is the number ##f(7)##.
What is the difference between
(i) ##f(7)##
and
(ii) ##f(y)## for ##y=7##?
(i) ##f(7)##
and
But it is not what you are writing, you are writing ##f(y)##, here ##y## is a variable.
Demystifier said:
An unspecified constant.
So, what is the example then? And why doesn't it satisfy the axioms? By the way what are they?
