Understanding Python Module Installation with Pip
  • Topic: Python
  • Thread starter Thread starter fog37
    Modules Python
8 replies · 3K views · last reply
fog37
TL;DR
Correct procedure to install modules that is not available
Hello,
I understand that modules are essentially Python file save as .py. These files contain both functions and/or classes. To use them in our programs, we must use the keyword import.
However, this works only if the module is available, i.e. already installed in the standard Python library, correct? A library, called package, is a folder containing lots of related modules and a file called __init__.py.
On the other hand, a "distribution" like Anaconda is a full collection of libraries together with other useful tools.
If the single module that we need is not available in the standard library, we must use the Python library manager pip and install it the same way we install an entire library. I guess an internet connection must be available since the pip is practically downloading the module from the web...
Thanks for any validation/correction...
There are other schemes besides pip most notably the anaconda distribution and its smaller sibling miniconda.
Anaconda comes with a host of commonly used modules preinstalled so you pretty much can get started without an internet connection.
When developing your code, you might try to develop your own modules and then you must extend the PYTHONPATH environment variable with a path to your modules. You can find details here:
https://www.tutorialspoint.com/What-is-PYTHONPATH-environment-variable-in-Python
and for building your own modules:
https://www.digitalocean.com/community/tutorials/how-to-write-modules-in-python-3
Python programmers also build environments that select what modules a given program uses to speed load time as Python pulls everything together:
https://realpython.com/python-virtual-environments-a-primer/
As a python programmer you must become comfortable with these topics.
Pycharm is arguably the best IDE for python development so you should check it out. MS VS Code Editor looks pretty good too. Both have debugging features. VS Code seems to load faster. Both have community editions (free, free free free!)
I'm a bad example of a python programmer in that I have yet to use virtual environments for anything. But my code is mostly useful utilities that I alone use.
A module does not have to be in a package to be importable. It can be a single module, not inside a package, and will be importable as long as its .py file is in a directory that is in sys.path.
The Python standard library itself is not a package (although it contains packages). It is just a directory that is in sys.path (because it is set up that way when Python is installed on your computer) and contains modules and packages that are shipped with the Python interpreter.
Thank you PeterDonis. So a package seems to be a synonym of library which is a directory (folder) of modules.
Why wouldn't the Python standard library not be a package is library=package=directory with modules?
No. What you describe is the default way that packages are stored in the filesystem (and you've missed some parts--the directory has to be a subdirectory of a directory that's in sys.path and has to have an __init__.py file in it), but that's not what defines what a package is in Python.
Here is what a package is in Python:
https://docs.python.org/3/tutorial/modules.html#packages
The first sentence of this section is:
Packages are a way of structuring Python’s module namespace by using “dotted module names”.
In other words, packages, in and of themselves, are defined by the way they structure Python's module namespace. The way in which this structuring of Python's module namespace connects with how things are stored in the filesystem is, properly speaking, an implementation detail; there is nothing in the Python language specification that requires a package to correspond to a directory in the filesystem. And, in fact, since Python's import mechanism itself is programmable, it is possible to have the import statement look for packages and modules in other ways besides the default way of looking through the directories in sys.path for a subdirectory with the given name that meets the requirements for a package.
Because it isn't. See above.
Btw, a general note: the Python documentation is actually very detailed, and it is highly probable that it already contains answers to a lot of questions you might have. I strongly recommend taking some time to read through it and become familiar with the topics it covers. The top-level page for the current release candidate of Python (3.8rc1) is here:
https://docs.python.org/3/index.html
You can use the version dropdown at the top to get to the corresponding top-level page for the documentation of any extant version of Python.
Hello,
Today I successfully installed the numpy module (which wasn't installed) using pip but I am not sure what was really going on exactly. On the command line, I typed python - m pip install numpy
  • Where did the pip program manager install the numpy module? In which folder can I find the numpy module (or package)?
  • Also, the pip program itself is not installed in the system32 folder. The folder system32 is the current folder, correct? How can I run pip from there?
  • pip is installed in the subfolder Scripts in the folder Python37 where I see the program python which is not installed in the subfolder system32...Is that the python interpreter? If so, can I use the interpreter directly if I click on it instead of using the IDLE or the command line?
However, it seems that the shortcuts to the IDLE and to the interpreter (Python 3.7 (64-bit)) are installed elsewhere in the Start Menu folder (see below). Is this a good practice?
Thanks!
The simplest way to find out where a Python package (numpy is a package) is installed is to start an interactive Python interpreter session, import the package, and then look at its __path__ attribute. Here's what happens on my machine when I do that (my machine is Linux, not Windows, but the interpreter commands would be the same):
Python:
Python 3.5.2 (default, Jul 17 2020, 14:04:10)
[GCC 5.4.0 20160609] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import numpy
>>> numpy.__path__
['/usr/local/lib/python3.5/dist-packages/numpy']
The system32 folder on Windows is not for programs; it's for system libraries. Programs are not installed there. I have no idea why you would need to run any program from that folder. As for pip, it doesn't matter which folder you run it from; it doesn't care what your current folder is.
Also, pip is not a standalone program, it's a Python module (actually it's a package, see note below). When you issue the command python -m pip install numpy, the program you are running is python; that program then loads the pip module and runs it as a script. See the Python documentation (remember what I said about the answers to your questions already being in the Python documentation?) here:
https://docs.python.org/3/tutorial/modules.html#executing-modules-as-scripts
Note that pip is actually a package, so when you run it as a script this way, the module that gets executed as a script is actually the __main__.py file in the package. See the Python docs (there's the docs again...) here:
https://docs.python.org/3/library/__main__.html?highlight=__main__ py#module-__main__
The python program in the Python37/Scripts folder is the python interpreter executable, yes. Python scripts that can be run as standalone programs also get installed there. So instead of typing the command python -m pip install numpy, you could just type pip install numpy and it should work. If you look at the source code of the pip script in the Scripts folder, all it really does is import the pip package and run the same function the __main__.py file in that package runs if you run it as a script with python -m.
As for using the interpreter directly, I don't know if clicking on it in Windows will bring up a command prompt window with the interpreter running, but you can always type "python" in a command prompt window and get an interactive interpreter session.
If by "good practice" you mean "what Windows always does with shortcuts", yes. Whether that is actually a good practice as far as usability is a different question. :wink:
Thank you PeterDonis. I really appreciate your inputs. It is true that the documentation has everything but sometimes it get overwhelming to read and after you facilitate the topic I can dig into the documentation with a different spirit.
For instance, in regards to pip, you mentioned that it is both a Python library/package installation management tool as well as a Python module...
In some cases, pip is used with the statement:
Code:
pip install modulename
while in other instances as
Code:
-m pip install modulename
The first part means to run pip as a module...
Code:
-m
Why would we want to run pip, which is a package installation tool, as a module? Also, when I don't use -m, things seem to work just fine...
Thanks
That's not quite what I said.
The package pip is what contains the actual Python code that does the work.
Inside that package, there is a module named __main__.py. That is what gets run if you type python -m pip install <something> at the command line, since that's how the python -m command works when you give it the name of a package. (If you give it the name of a standalone module that's not in a package, it just runs that module.) The module __main__.py inside the pip package is just a little bit of stub code that calls a function elsewhere in the pip package to do the work.
There is also a standalone script called pip, which is what gets run if you type pip install <something> at the command line. (This assumes that the script has been installed somewhere on your command line's search path.) This script is also just a little bit of stub code that calls a function in the pip package (the same one the module __main__.py inside the pip package calls) to do the work.
So python -m pip install <something> and pip install <something> are just two different ways of calling the same code to do the same work. Which one you use is really just a matter of personal preference.
