Understanding Schwarz Inequality: A Primer on Real and Complex Spaces
  • Context: Graduate
  • Thread starter Thread starter jammidactyl
    Inequality
The discussion centers on the Schwarz inequality and its implications in both real and complex spaces. Participants explore the relationship between ordered rings and metric spaces, emphasizing that the Schwarz inequality holds in any inner-product space, not just in R^n. The conversation also touches on the topological properties of uniform spaces and their relevance to analysis, as well as the distinction between differential geometry and algebraic geometry. Key references include the article "Geometry, calculus and Zil'ber's conjecture" for further exploration of these concepts.
  • Understanding of inner-product spaces and their properties
  • Familiarity with the concepts of metric spaces and uniform spaces
  • Knowledge of algebraic structures, specifically ordered rings and fields
  • Basic principles of differential geometry and algebraic geometry
  • Study the properties of inner-product spaces in detail
  • Research the concept of uniform spaces and their applications in analysis
  • Examine the relationship between algebraic geometry and differential geometry
  • Read "Geometry, calculus and Zil'ber's conjecture" for insights on the discussed topics
Mathematicians, students of analysis, and researchers in algebraic and differential geometry seeking to deepen their understanding of the Schwarz inequality and its applications across different mathematical fields.
jammidactyl
I'm thoroughly confused by the Schwarz inequality.
In many books on analysis, the author defines the Euclidean distance and then shows that the distance function is a metric, ie the Schwarz inequality holds. This isn't very satisfying as I feel it masks the properties of R^n that generate this relation.
In reading on Wikipedia, I came across the topological idea of a uniform space. Although I don't quite understand the characterization of a uniform space, it satisfied me to read that we could salvage some parts of analysis without resorting to a real-valued distance function. We can still formalize the notion of "relative closeness".
From a simple algebraic viewpoint, one can easily define an absolute value in an ordered ring. This order relation satisfies the triangle inequality, and I also believe it satisfies the Schwarz inequality. So is every ordered ring a "metric space" where the standard metric takes on values from the ring?
This makes sense until we look at the complex plane. It's not an ordered field (or ring) but we can still define a absolute value. This work because we identify the complex plane with R^2... but that brings me back the original question, what properties of R^n allow us to prove the Schwarz inequality?
If this seems like a half-baked post, it is... I'm having a hard time even formulating my question and wanted to see if somebody could direct me to further reading on these ideas (my home library is coming up short).
Um, well it might help you to know that the C-S inequality in R^n is a special case of the C-S inequality that holds in any inner-product space. That is, although there might be more abstract generalization of the C-S inequality, the only property/structure you need to prove the case in R^n is that of an inner product space, hence it holds in any inner product space.
An inner product space is a vector space together with a function of two variables mapping into some field satisfying a few axioms. So it seems that a ring is not sufficient for some reason I have no intention of investigating a 5h42 AM; it has to be a field.
Ah... right an inner product space.
I'll tell you what really motivates these questions. I'm having trouble sorting out the topological and algebraic properties of R^n that generate the differentiable structure. I found an article that talks about some of the ideas that interest me:
http://www.math.ucla.edu/~asl/bsl/0201-toc.htm
What field does this fall under? I'm very much interested in logic, but also differential geometry.
Thanks!
There isn't going to be a unique construction.
Anyways, the ordering relation isn't necessary to do differential geometry. The simplest case is:
Let k be an algebraically closed field.
Let K = k(t_1, t_2, \ldots, t_n) be the field of rational functions over k in n variables.
Then the module \Omega^1_{K/k} of differential forms of K over k is abstract K-module generated by the formal basis elements dt_i. The derivation d:K \to \Omega^1_{K/k} is uniquely determined by the sum rule, the product rule, and the constraints d(t_i) = dt_i.
We obtain the cotangent space at any point P in k^n by further imposing the relation that f dt_i = g dt_i whenever f(P) = g(P).
those of us inalgebraic geometry, where that construction arises, do not consider ourselves to be doing diffrential geometry, even we are taking derivatives. when we use the phraSE differential geometry we mean there is also a length and angle measure present. so curvature is an essential ingredient of differential geometry.
i.e. not aLL CIRCLEs SHOULD BE ISOMORPHIC IN DIFFERENTIAL GEOMETRY, as they are in algebraic geometry.
Ah! I never really formed a mental distinction between differential geometry and differential topology.
My point still stands, I think -- we can still give an algebraic construction of the cotangent sheaf, and thus construct the tensor algebra over our variety. From there, we can do (the algebraic analog of) anything we want, such as study the geometry arising from a metric tensor. On algebraic varieties, though, I only ever hear people talking about differential k-forms, and occasionaly tangent vectors. Is there a serious flaw in the theory of the tensor algebra over an algebraic variety, or is it just not useful for the questions often asked?
  • · Replies 19 ·
  • · Replies 16 ·
