Understanding tension and centripedal force in a puck and weight
The discussion revolves around understanding the behavior of tension and centripetal force in a scenario involving a puck on a table and a weight hanging from a rope. Participants explore the mechanics of forces acting on both the puck and the weight, considering the implications of tension in the rope and its directional characteristics.
  • One participant describes the mechanical solution to the problem, detailing the force diagrams and equations related to tension and centripetal acceleration.
  • There is a question regarding the nature of tension, specifically how it can be both inward on the puck and upward on the weight, leading to confusion about the forces involved.
  • Another participant challenges the notion that tension in a rope has a direction toward one end and away from the other, suggesting a need for clarification.
  • A participant attempts to diagram their understanding of the forces, indicating a realization of the centripetal acceleration being linked to the tension in the rope.
  • Several participants agree that tension in the cord acts in both directions, affecting both the puck and the weight, and emphasize the importance of recognizing force pairs.
Participants generally agree on the dual nature of tension in the rope affecting both the puck and the weight. However, there remains some uncertainty regarding the explanation of how tension behaves and its directional characteristics.
Some participants express uncertainty about the conditions affecting the forces, particularly regarding the angle created by the rope and how it influences the tension experienced by both the puck and the weight.
ago01
For practice I did the following problem:
Solving this problem mechanically was simple enough using the following force diagrams:
Then
$$F_{net_M} = T - Mg = 0$$
Due to the stationary condition
$$T = mg$$
and
$$F_{net_m} = T = ma_c$$
$$T = ma_c$$
Because centripedal acceleration is inward the direction of the tension. The rope is pulling on the puck to stay in the circle, because without it the puck would simply fly away.
So we find after substitution:
$$Mg = m\frac{v^2}{R}$$
and after some algebra
$$v = 1.8 \frac{m}{s}$$.So algebraically this problem wasn't terrible. Understanding the nature of the forces wasn't too bad either...at least mechanically. However I'm left wondering how exactly this tension is behaving.
Since the the rope is pulling inward on the puck it is imposing some centripedal force on the puck, and this force is causing the centripedal acceleration experienced (and what is holding the puck on the radius).
However, the rope is also pulling up on the weight. So the tension in the rope is inward facing (towards the hanging weight), yet the weight experiences some upward tension to balance out gravitational force as well! My intuition is failing me.
Is this because of the right angle it is creating? The tension is inward on the table, but upward on the weight opposite gravity. Does this have something to do with the angle it's creating? If gravity and centripedal acceleration are both inward (gravity being "down and in") I would expect the rope to be slack. I'm trying to quantify this but I am failing at coming up with a way to explain it. Which bothers me because I've seen the experiment done before.
Can you clarify what you mean when you say that tension in a rope has a direction toward one end and away from the other?
Hint: It does not.
Hint: It does not.
Sure, I'll diagram what's going on in my brain
This was my original post diagrammed. However, it appears I forgot a very important condition...
I'm not sure if this is totally correct...but it feels closer. So because the puck is spinning a circle, the changing velocity is generating a centripedal acceleration. This centripedal acceleration is the inward tension. But, the puck is also "pulling back" on the weight by being held along the radius by this acceleration.
Right. The tension in the cord works both ways.
It pulls left on the corner of the hole in the table. It pulls right on the puck.
It pulls down on the corner of the hole in the table. It pulls up on the weight.
I see yep. I'm glad I asked. This is a good checkpoint for me on making sure I'm getting force pairs correctly.
Thank you!
  • · Replies 51 ·
  • · Replies 19 ·
15K
  • · Replies 19 ·
  • · Replies 39 ·
  • · Replies 49 ·
