Understanding the Conversion Formula for Venturimeter Readings
  • Thread starter Thread starter ujjwal kapil
    Doubt
3 replies · 1K views
ujjwal kapil
Hi all
I was trying to solve some numerical problems on venturimeter. I got stuck due to a formula, that I was not able to make sense of. It is a conversion of reading of differential manometer in mercury to corresponding reading in water. I've attached the question, please help me understand it.
Hi ujjwal kapil. http://img96.imageshack.us/img96/5725/red5e5etimes5e5e45e5e25.gif
Draw a U-tube manometer showing a difference in mercury levels. Now, add water above both surfaces of mercury, and show pressures of P1 and P2 acting on that water.
Apply your ρgh formula, etc., and derive the pressure differential P2 - P1 in terms of the other quantities present. Write your working here.
I have found an answer, but not in accordance with the solution.
20cm of Hg= 272cm of H2O, but it is given as 252 in the solution.
Keep it simple, draw a symmetrical U-tube.
You overlooked the water! On one side you have P1 and a column of h metres of H2O balanced on the other side by P2 and a column of h metres of Hg.
So try this again. Keep it as algebra, don't substitute numbers. We're aiming towards that expression you circled, remember?
