Understanding the Relationship between the Hamiltonian and Magnetic Field
The discussion revolves around the relationship between the Hamiltonian in the presence of a magnetic field and the vector potential. Participants explore the mathematical expressions for the Hamiltonian, particularly how to express one form in terms of another, and the implications of these transformations on physical interpretations.
  • One participant presents two forms of the Hamiltonian, Ho and H1, and questions their equivalence in the context of a magnetic field.
  • Another participant clarifies that the difference between Ho and H1 lies in the definition of momentum, with H1 incorporating the vector potential A.
  • There is a discussion about the correct form of the momentum in H1, with some participants asserting it should be (p - eA).
  • Participants debate the validity of a transformation involving the exponential of the vector potential and its implications for the Hamiltonian.
  • One participant introduces the concept of a unitary operator and its role in demonstrating that Ho and H1 have the same spectrum of eigenvalues.
  • There is uncertainty regarding the necessity of considering degeneracies in the eigenvalue spectrum.
  • Some participants express confusion about the mathematical expressions and seek clarification on their implications.
Participants generally agree on the mathematical forms of the Hamiltonians but disagree on the implications and correctness of certain transformations. The discussion remains unresolved regarding the necessity of considering degeneracies and the broader implications of the vector potential in the Hamiltonian.
There are limitations in the discussion regarding the assumptions made about the vector potential and its dependence on space and time. Some participants note that if the curl of A is zero, the vector potential may not need to be included in the Hamiltonian.
ziyad
I have a question regarding the Hamiltonian in a magnetic field.
First Hamiltonian with potential V is given by
Ho = (1/2m)*p^2 + V
but if a vector potential A is also present then
H1 = (1/2m)*(p+eA)^2 + V
there is a way to write H1 interm of Ho
H1 = exp(-ier.A) Ho exp(ier.A)
where r is position
and r.A is dot product of position and vector potential
Any one knows Why? are these both forms equal and how to convert one into another
The expressions you wrote are two forms of the same Hamiltonian. The difference consists of p (momentum). In H_0 p is the classical momentum (mv) whereas in H_1 p is the canonical momentum (mv+eA).
BTW. In H_1 you must have (p-eA)
clive
Hey clive, yeah it has to be p-eA for it to be equal,
but how is the third equation equal to the second.
That [itex]\hat{U}[/itex] is the potential energy operator.Is there any connection between this operator and the magnetic potential vector operator...([itex]\hat{A}[/itex])?
What do you mean by "e" (in the third equation) ziyad?
E sarcina elementara "e".
It's the elementary charge "e",i'm sure of it.
ziyad said:
... there is a way to write H1 interm of Ho
where r is position
and r.A is dot product of position and vector potential ...
No, this is not the way.
What you have written down comes from
eiR∙a/h_bar P e-iR∙a/h_bar = P - a .
In this relation, however, the vector a is fixed. It has no dependence on space (although, it could depend on time). If it were the case that a had some kind of functional dependence on space – and hence, we would have "±iR∙a(R)/h_bar" in the exponentials – then it would no longer be the case that the left-hand side equals the right-hand side.
The general expression goes like this:
eiG(R,t)/h_bar P e-iG(R,t)/h_bar = P – (grad G)(R,t) .
There is definitely something more to be said here (though, for the moment, I'm not quite sure what it is).
clive 'e' is the charge
ok i wrote it wrong. here i scanned the equations
http://www.public.asu.edu/~ziyads/hamiltonian.gif
eye in the sky, yes ur correct. A is a constant vector.
what is that equality called. and where can i read more about it.
looking at the equation u mentioned. by changes signs
exp(-ier.A/hbar) Ho exp(ier.A/hbar) = Ho+eA
Now if i expand the square in the original H1 i get
H1 = Ho + (1/2m)(ep.A + eA.p+ (eA)^2)
How do i make this second term equal to just eA so i can use the equality u mentioned.
eye in the sky, how r u able to write equations in this forum.
... The general expression goes like this:
I don't know of any special names for these equalities. The first relation (in which the vector a is a constant) is directly related to the notion of the operator mR as the generator of "boosts". A similar equality, in which the roles of P and R are reversed, is directly related to the notion of the operator P as the generator of "(spatial) translations". All of these equalities are equivalent to the basic canonical commutation relations for R and P; i.e.
[Rk, Rl] = [Pk, Pl] = 0 ,
[Rk, Pl] = ihbar δkl .
Alternatively, they are equivalent to:
(i) the action of P in the {|r>} representation is given by -ihbargrad ;
or
(ii) the action of R in the {|p>} representation is given by ihbargradp ;
As for where to read more about these matters, I'm sorry but I can't think of any good elementary references. Perhaps someone else can point you in the right direction.
_____________
You have made an error here. The right-hand side should read H1, as before.
_____________
... A is a constant vector.
If A is a constant vector, then there is no reason to include it in the Hamiltonian. More generally, if curl A = 0, then there is no reason to include A in the Hamiltonian at all. In that case, the equations of motion for the system can be derived from a "scalar potential" alone without the need for the introduction of a "vector potential". (This fact has a deep connection with the equality quoted above in which the expression P – (grad G)(R,t) appears on the right-hand side.)
Having said that, I am beginning to see a little better what I was talking about when I said (back in post #7):
Yes, yes. There is something here about being able to 'remove' the A(R,t) term by means of a certain kind of unitary transformation if, and only if, curl A = 0 (i.e. A(r,t) = grad G(r,t) , for some function G). ... But it's all still a bit too 'fuzzy' for me to put my finger on.
_____________
If you click on the "quote" tab on any given post, you will be able to see precisely how the equations have been produced. Whenever I need special symbols (e.g. Greek letters), I copy and paste them from a "storehouse" of symbols in a WORD document I keep. Those symbols have been gathered by clicking on INSERT → SYMBOL in the upper menu of Microsoft WORD.
Perhaps using the Latex code can be easier. I haven't tried.
This is getting really complicated :cry:
a friend told me to look at H1*Phi(r) for arbitrary phi(r)
where phi(r) is the wavefunction
and both forms will give the same result.
although I'm not sure how exactly
We have
e-ieR∙A/h_bar Ho eieR∙A/h_bar = H1 ,
where A is a constant vector, and
Ho = P2/2m + V(R) ,
and
H1 = (P + eA)2/2m + V(R) .
Now what exactly do you want to show?
That these both r same
one can be derived from another, or H1*phi(r) for arbitrary Phi(r) should give same result using either formulas.
Sorry dude. I'm bugging u so much
It sounds like you want to say that Ho and H1 have the same spectrum of eigenvalues. Is that what you want to say?
actually both forms of H1 should have the same spectrum of eigenvalues.
Okay, now we are "rolling".
First of all note that the operator
S(R) ≡ e-ieR∙A/h_bar
is a unitary operator. That is,
S-1(R) = S(R) .
So,
H1 = S(R)HoS(R) .
Therefore, a ket |ψ> is such that
Ho|ψ> = E|ψ> ,
if, and only if, the ket |φ> ≡ S(R)|ψ> is such that
H1|φ> = E|φ> .
This shows that Ho and H1 have same spectrum of eigenvalues.
Next, observe that
φ(r) ≡ <r|φ>
= <r|S(R)|ψ>
= <r|e-ieR∙A/h_bar|ψ>
= e-ier∙A/h_bar <r|ψ>
= e-ier∙A/h_bar ψ(r) .
This shows that corresponding eigenvectors of H1 and Ho (i.e. the ones which have the same eigenvalue) differ by a mere phase factor (given by
e-ier∙A/h_bar ).
... Is there anything else?
Note that to be completely rigorous, however, we would need to say a few words also about how the above conclusions are still valid in case of degeneracies. (This requires further thought.)
:smile: :smile:
That wasn't so bad. It looks so simple now.
Eye in the sky. thanks for ur help dude. I think that's the solution, i don't think degeneracy is needed. this is perfect as it stands.
YAY!
So glad to have been of help! :wink:
(Good luck on the exam! :smile: )
  • · Replies 21 ·
  • · Replies 35 ·
