Understanding VCEsat: The Impact of Resistance on BJT at Different Currents
  • Thread starter Thread starter Genji Shimada
The discussion revolves around the concept of VCEsat in bipolar junction transistors (BJTs), particularly focusing on how resistance affects VCEsat at different collector currents. Participants explore the relationship between base current, collector current, and the resulting voltage drop across the collector-emitter junction in saturation. The conversation touches on both theoretical and practical aspects of transistor operation.
  • One participant suggests that VCEsat is due to energy loss from resistance between the emitter and collector, questioning why the voltage drop increases with higher currents.
  • Another participant asks for clarification on whether the discussion pertains to the same transistor at different currents or different transistors, noting that different transistors can have varying characteristics.
  • Some participants discuss the impact of base current on the saturation of the transistor, suggesting that increasing base current could push the transistor further into saturation, affecting VCEsat.
  • There is a mention that VCEsat may not solely be a product of bulk resistance, with references to the physics of electrons and band-gaps being potentially relevant.
  • One participant acknowledges that silicon has inherent resistance, which contributes to a non-zero VCEsat, and discusses how Ohm's law applies to the relationship between collector and base currents.
  • Another participant points out the importance of considering both junctions (base-emitter and base-collector) conducting current in the saturation region.
Participants express varying levels of certainty regarding the factors influencing VCEsat, with some agreeing on the role of resistance while others introduce additional complexities. The discussion remains unresolved regarding the precise mechanisms and relationships at play.
Some participants note that the values of VCEsat can vary based on specific transistor characteristics and operating conditions, and there is acknowledgment of potential uncertainties in the provided values.
Readers interested in transistor operation, electrical engineering, and the effects of resistance in semiconductor devices may find this discussion relevant.
Genji Shimada
Hi! The VCEsat which occurs between the emitter and the collector of a saturated bjt is duo to the inevitable loss of energy caused by the resistance between the emitter and the collector, right?
If so, why this voltage drop is bigger at higher currents and lower at smaller ones? For example at Ib to Ic ratio of 1 to 10, at Ic=250mA Vcesat=,2V. But at the same base to collector current ratio, at Ic=500mA Vcesat=1V.
Also I always wanted to ask someone, as an engineer, how deep do you need to go with physical explanations?
Are you talking about the same transistor at different currents, or two different transistors?Different transistors can have different characteristics.
But if the same transistor, note that you have doubled the base current, so couldn't that push the transistor further into saturation? Also, doubling the base current would probably push the curve a bit, and the exact 1:10 ratio would have moved slightly, so I'm not sure your description is completely accurate.
I should add - I'm not sure that Vce is totally a product of bulk resistance, some of the physics of electrons, holes, band-gaps, etc probably play into it, but that is beyond me, or I've forgotten it if I ever did know.
Nope, its the same transistor. Some transistors in their datasheet have values of Vcesat for several different currents. And to ensure the transistor is saturated, the base current is 1 10th of the collector one. And for example at 250mA Ic you got 0,2V Vcesat, but for Ic=500mA Vcesat = 0,7V(These values arent 100% sure since I may have forgotten them). Oh and so, if there are some other quantum-like reasons for Vcesat you don't necessarily need to know about them, right?
Vce(sat) is a voltage difference between Vbe - Vbc. And in saturation region both of this junction (b-e and b-c ) conduct the current.
http://ecee.colorado.edu/~bart/book/book/chapter5/ch5_3.htm#5_3_4
And do not forget about "silicon resistance" and "leads" resistance.
If it was due to resistance why are you surprised?
V= I*R
V= I*R
Yep, you're right. I don't know why I struggled about it so much. Since the silicon itself has some resistance you can never get away with 0V drop across CE. And so you got around 0,2V Vcesat. If the ratio between Ic and Ib is still 1/10, if the currents are bigger, duo to Ohms law Vcesat will increase. But if you increase the base current even more, you turn on the transistor more and reduce it's depletion layer even further, decreasing the resistance and Vcesat will be less.
Thanks!
Thank you guys for the replies
23K
  • · Replies 60 ·
17K
  • · Replies 23 ·
