Understanding Work Calculations with Inclines
10 replies · 3K views · last reply
Sarah00
Diagram of a block on a smooth incline rising to the right at 37 degrees, with a force F pointing up the slope along the direction of motion.
Guys, consider the above image.
Let the incline to be smooth.
If I want to find NET WORK ..
There are 2 formulas ..
W = Fd and W = Change in Mecahnical Energy
In First Formula
Wnet = Wf + Wmg
Wnet = Fd - mgsin37 * d
In second Formula
Wnet = Change in KE + Change in PE
Fd = Change in KE + Change in PENot I got confused .. I know I am doing right..
But in first formula: Wnet = Wf + Wmg but in the second I substittued Fd only for Wnet
So which one is Wnet? I hope you get my point
W = Fd
W = Change in KE + Change in PE
not a problem needing solution. It is about the concepts
I think my question was not clear enough..
I will try to paraphrase it..
I know that work is the vector product of displacement and force.
If we have more than one force, the net work is the sum of work for each force.
So, as we have in the incline: Wnet = Wmg + WF
Now, we move to concept of work and its relation to energy.
Net work is the change in the mechanical energy.
Here, Wnet is only WF right? Not Wmg + Wf.
So, sometime we consider the Wmg in Wnet and sometime not .. Please help me to resolve this confusion
If the incline is not frictionless, you need to include the work done by the force of friction. You cannot just drop it out.
Thanks for your reply but I stated in the second line of my post that the incline is smooth, so no friction
Oh, well then the friction term goes away for both formulas, and they are the same, no? Maybe I'm missing your question... :smile:
My confusion point is in the formula:
Wnet = Change in Mechanical Energy
What does Wnet mean here?
Just the change in potential energy ΔPE = mgΔh.
I think you're confused because the Wnet that you use in the two different equations mean different things. In your first equation, the work is the sum of the work due to gravity and the work due to the applied force, which equals Wnet. An important detail that you're missing is that this Wnet in this case is also equal to the change in kinetic energy, meaning that you get the equation Change in kinetic energy = Fd - mgsin37d. In your second equation, work is considered to be only the work that isn't conserved. The change in energy on the right side now includes the change in kinetic energy. Since the change in PE that you use here is also equal to mgsin37d, you end up getting the equation Change in kinetic energy = Fd - mgsin37d, which is also what you get in the first equation if you sub in Change in kinetic energy for Wnet. Basically, you accounted for kinetic energy in the work in the second equation but not the first. They are both right, but the two values for work aren't referring to the same thing in both cases.
Thanks, I figured out that they are equal.
But if the questions asked me to find Wnet .. Which one is Wnet?
Lets take this question:
A 1 kg rock is thrown directy upward with an initial velocity of 20 m/s. Assume no air resistance, the net work done to reach the maximum height is: ___
Now ..
If I used the first formula .. The only force I have is force of gravity. So Wnet = Wmg = mgd = 1*10*d = 10*d = 10 * 20 = 200 J
But by using second formula .. Wnet = Change in Mechanical Energy = 0 J
I read the replies again ..
Wnet = W1+ W2 + W3
This Wnet = KE NOT Wnet = KE + PE
It depends whether you mean the net work done by the force (##F d = \Delta PE + \Delta KE##), or the net work done on the block (##\Delta KE=F d - mgh##).
