Uniform Circular Motion and Centripetal Acceleration
The discussion centers on the application of the centripetal acceleration formula, a_c = v²/r, in scenarios involving variable speeds. It is established that while this equation is typically applied under constant speed conditions, it can also be adapted for variable speeds by considering the instantaneous speed at any given moment. The conversation emphasizes the importance of understanding both centripetal and tangential components of acceleration when speed changes, particularly in contexts such as vertical circular motion. The Frenet-Serret apparatus is recommended for further exploration of this topic.
  • Understanding of centripetal acceleration and its formula a_c = v²/r
  • Basic knowledge of derivatives and their role in calculating instantaneous acceleration
  • Familiarity with vector calculus concepts, particularly the Frenet-Serret apparatus
  • Concept of tangential acceleration and its relationship to variable speeds
  • Study the application of the Frenet-Serret apparatus in vector calculus
  • Learn about the relationship between centripetal and tangential acceleration in circular motion
  • Explore the concept of instantaneous acceleration and its mathematical definition
  • Investigate the behavior of objects in vertical circular motion and how speed varies at different points
Students of physics, particularly those studying mechanics, as well as educators and anyone interested in the dynamics of circular motion and acceleration concepts.
Nathanael
Homework Helper
In introductory physics books (or at least mine) it limits the equation a_c=\frac{v^2}{r} to the sitaution where the speed around the circular path is constant. It enforces the idea that the speed is CONSTANT.
But wouldn't the equation also apply to non-constant speeds? (a_c would just change from being a constant to being a function of the speed)
It would be very counter-intuitive to me if this equation did not apply to variable speeds (because why does this instant in time care about the speed of the next instant in time?)
So my question is, can you also use this equation for variable speeds?
Some parts of your question are dealt with here: http://www.sweethaven02.com/Science/PhysicsCalc/Ch0119.pdf
The machinery required to solve for the general case of centripetal acceleration for an object constrained to travel in a circle of constant radius, but with variable speed, is discussed ... you should be able to work through to the answer on your own from this point.
And if you want to go further, learn the Frenet-Serret apparatus; usually taught as part of vector calculus - calc 3.
Is not the definition of acceleration the rate of change of velocity over time?
Is it possible to have instantaneous acceleration? A classic definition of \overline{a} = (v_f - v_i) / t would be undefined at t = 0.
The mathematical definition would be the limit (if one exists) of the average rate of change (vf-vi)/(tf-ti) as tf approaches ti without actually getting there.
That is to say that acceleration is the derivative of velocity.
http://en.wikipedia.org/wiki/Derivative
Your equation does give the centripetal component of the acceleration even when the speed is changing. But if the speed is changing, there is also a tangential component of the acceleration.
You will probably meet this later on if your course deals with objects moving in a vertical circle, where the speed is greater at the bottom of the circle than at the top.
Nathanael said:
...because why does this instant in time care about the speed of the next instant in time?
The following is a general remark about acceleration. Acceleration is the rate of change of velocity. You can't determine acceleration at a given instant of time by only knowing velocity at that instant of time. You need to know it in some open interval centered on that instant of time. This is part of the basic definition of a derivative.
  • · Replies 23 ·
  • · Replies 37 ·
  • · Replies 24 ·
  • · Replies 19 ·
  • · Replies 16 ·
