Uniform Circular Motion puzzle
The discussion revolves around the mathematical representation of uniform circular motion, focusing on the position, velocity, and acceleration of a particle moving in a circular path. Participants explore the implications of angular frequency and the dimensional consistency of trigonometric functions in this context.
  • One participant presents the position function for circular motion and derives the velocity and acceleration vectors, suggesting a relationship between their magnitudes.
  • Another participant points out that assuming an angular frequency of 1 is dimensionally inconsistent and suggests using a general angular frequency, ω.
  • A different participant emphasizes that the argument of sine and cosine functions must be dimensionless, indicating that time must be multiplied by a constant with appropriate units.
  • There is a question about whether the magnitudes of the derived vectors remain equal even with the correct angular frequency applied.
  • Participants discuss the derivatives of trigonometric functions, specifically the derivative of cos(ωt), and its implications for understanding velocity and acceleration in circular motion.
  • One participant concludes that the magnitudes of velocity and acceleration can be expressed as v = ωr and a = ω²r, indicating a resolution to their earlier confusion.
  • Another participant adds a note on the dimensional consistency of functions that can be expressed as power series, reinforcing the need for pure number arguments.
Participants express varying views on the assumptions made regarding angular frequency and the dimensionality of trigonometric functions. While some participants agree on the need for a general angular frequency, others raise questions about the implications of these corrections. The discussion remains unresolved regarding the initial assumptions and their effects on the derived relationships.
There are limitations regarding the assumptions made about angular frequency and the dimensionality of the arguments in trigonometric functions. The discussion also highlights the need for clarity in the application of derivatives in this context.
Ludwig
The position function for a particle moving on a circle (with constant speed) is:
## \vec{r}(t)=\left \langle r\,sin(t), \, r\,cos(t) \right \rangle ##
Taking the first and second derivatives,
## \vec{v}(t)=\left \langle -r\,cos(t), \, r\,sin(t) \right \rangle ##
## \vec{a}(t)=\left \langle -r\,sin(t), \, -r\,cos(t) \right \rangle ##
suggesting that the magnitudes of each are equal (i.e., r = a = v).
However, I frequently see this equation:
## \sum F = ma_{c}=m \frac{v^2}{r} ##
...but wouldn't ## a_{c}=\frac{v^2}{r} ## simply be equal to r?
If so, why express it in the above form?
Writing down your expressions, you have implicitly assumed that the angular frequency is 1. This is not always the case and is dimensionally inconsistent as the angular frequency should have units s-1. Instead, use a general angular frequency ##\omega## such that the argument of the sines and cosines becomes ##\omega t##.
sin (t) and cos (t) don't make sense. You can't take the sin or cos of something with units. Try looking up sin (10 second) !
t must be multiplied by a constant, [itex]\omega[/itex], with units of s-1, or rad s-1.
[itex]\omega[/itex] has an easy physical interpretation. Agreed?
Even with the correct arguments, won't the magnitudes of the vectors still be equal?
I.e., ##\sqrt{(\pm rCos(\omega t))^{2}+(\pm rSin(\omega t))^{2}}=\sqrt{(- rSin(\omega t))^{2}+(\pm rCos(\omega t))^{2}} = r##, right?
I'm sure that there is something I'm missing, but I don't know what.
what is the first derivative of ##cos({\omega}t)## with respect to t?
Yes.
Jbriggs444 has identified another reason why you're confused. You need to think about the answer to this poster's question. It is not [itex]-sin(\omega t)[/itex].
Chain rule. Right. Well that clarifies a lot!
So the magnitudes end up being:
##v=\omega r##
##a=\omega^{2}r,## right?
Excellent. This is a useful result! Thanks for indicating the way out of my confusion.
Good!
It's worth remembering that any function (such as sin, cos, ln, exp) that can be expanded as a power series can only have a pure number as argument, otherwise we'd be adding together terms with different units.
  • · Replies 19 ·
