How Do You Prove a Function is Not Uniformly Continuous?
To prove that a function f is not uniformly continuous on a set X, it is necessary to demonstrate the existence of an ε > 0 and sequences (p_n) and (q_n) in X such that the distance d_X(p_n, q_n) approaches 0 while the distance d_Y(f(p_n), f(q_n)) remains at least ε. The proof begins by showing that if d(p_n, q_n) approaches 0, then f cannot be uniformly continuous, as it contradicts the definition of uniform continuity. Conversely, if f is not uniformly continuous, it implies that for every δ > 0, there exist points x and y in X such that d_X(x, y) < δ leads to d_Y(f(x), f(y)) ≥ ε. A concrete example, such as f(x) = x^2, illustrates this concept, where specific sequences can be constructed to satisfy the required conditions. The discussion emphasizes the importance of defining appropriate sequences to complete the proof effectively.
Incand
Let ##f:X \to Y##. Show that
##f## not uniform continuous on ##X## ##\Longleftrightarrow## ##\exists \epsilon > 0## and sequences ##(p_n), (q_n)## in ##X## so that ##d_X(p_n,q_n)\to 0 ## while ##d_Y(f(p_n),f(q_n))\ge \epsilon##.
Let ##f:X\to Y##. We say ##f## is uniform continuous on ##X## if ##\forall \epsilon >0 \exists \delta > 0## so that
##d_Y(f(x),f(y))< \epsilon## ##\forall x,y\in X## for which ##d_X(x,y)< \delta##.
I was hoping someone could take a look at my proof and check if it's correct or not. I found the second part especially hard to formulate so I'm mostly unsure about that part.
Starting with ##\Longleftarrow##
##d(p_n,q_n) \to 0## means by definition that
##\forall \delta > 0## ##\exists N## so that ##d(p_n,q_n) < \delta## for ##n \ge N##. But then ##f## can't be uniform continuous since the points ##p_n, q_n \in X## and ##d_Y(f(p_n),f(q_n))\ge \epsilon_0## we have a counter example to
##d(x,y)<\delta \Longrightarrow d(f(x),f(y)< \epsilon## if we take a ##\epsilon < \epsilon_0##.
##\Longrightarrow##
That ##f## is not uniform continuous implies that ##\exists \epsilon >0## so that ##\forall \delta > 0## there exists ##x,y\in X## so that
##d_X(x,y)< \delta \Longrightarrow d_Y(f(x),f(y))\ge \epsilon##. Let's select some ##x,y## satisfying this and set ##p_n = x## and ##q_n =y## and we're done.
Incand said:
##\Longrightarrow##
You're not finished. You haven't defined the sequences p_n and q_n.
Maybe it helps to look at a concrete case: f(x) = x^2. This is not uniformly continuous. Pick \epsilon = 1. Then for any \delta &gt; 0, we can find an x and y such that |x-y| &lt; \delta, but |f(x) - f(y)| &gt; \epsilon. You just let x = \frac{1}{\delta}, and let y = x+\frac{\delta}{2}. Then even though |x-y| &lt; \delta, |x^2 - y^2| = 1 + \frac{\delta^2}{4} &gt; \epsilon.
So it's not uniformly continuous. But how does your argument show that there is a sequence p_n and a sequence q_n such that |p_n - q_n| \rightarrow 0 but |(p_n)^2 - (q_n)^2| &gt; \epsilon?
(It's not hard to come up with such a sequence, but it doesn't seem to follow immediately from your proof.)
Likes Incand
Good catch there! I tried to fix the problem:
So we have ##d_X(x,y)<\delta \Longrightarrow d_Y(f(x),f(y))\ge \epsilon##.
Set ##N= floor(1+1/\delta)## Then ##d_X(x_n,y_n)\le 1/n < \delta## for ##n\ge N## implies ##d_Y(f(x),f(y))\ge \epsilon##.
So for each ##n## select ##x_n,y_n## satisfying the above which will then form two sequences ##x_n## and ##p_n## for which ##d_X(x_n,y_n)< 1/n \to 0##.
For your example we could set ##p_n = n+1/n## and ##q_n = n## then ##|p_n-q_n| = 1/n \to 0## while ##|(n+1/n)^2-n^2| = 2+1/n^2 \to 2##.
In the proof above we can shift the indexes to start counting from ##1,2,\dots## by setting ##p_1 = x_N, p_2 = x_{N+1}, \dots ##
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 40 ·
