How Much Does Earth's Atmosphere Weigh?
  • Thread starter Thread starter nikita33
    Unit
The discussion focuses on calculating the mass of Earth's atmosphere and its average density. It states that there are 14.7 pounds of air per square inch of Earth's surface, and the density of air at sea level is approximately 1.27 g/L. To find the mass of the atmosphere, one must first determine the Earth's surface area in square inches and then apply the density formula. The user expresses uncertainty about unit conversions, particularly regarding the radius of the Earth in miles. The conversation emphasizes the importance of correctly applying the density equation and converting units to solve the problem accurately.
nikita33
above each square inch of Earth's surface is 14.7 lbs of air. the density of air at sea level is about 1.27g/L. the Earth is 7930 miles in diameter and has a mass of 5.98 x 10^24kg.
a.) use the data above to determine the mass in kg of the Earth's atmosphere.
b.) determine the average density of Earth in grams per milliliter.
i think the only relevant equation is d=m/v. everything else seems to be unit conversions. this problem really isn't about the atmosphere, but rather how well i can convert units, and apparently not well.
im looking for the mass of the atmosphere, so i use m = dv
d is 1.27g/mL
i derive v from 4/3pir^3
but i have the radius in miles. does this matter?
i would get (1.27g/mL)(2.55x10^11) since i need it in kg
(1.27 x 10^-3kg)(2.55x10^11) = 3.24 x 10^8 kg/mL?
im sure I am hopelessly wrong. i don't really want to do part b until i get part a.
(a) We're given that there are 14.7 pounds of air per square inch of Earth's surface area. If you can figure out how many square inches of surface area the Earth has, can you take it from there?
(b) The equation you had, d=m/v, applies here.
  • · Replies 17 ·
