Unit tangent, unit normal, unit binormal, curvature
4 replies · 5K views · last reply
s3a
Question:
"Find the unit tangent, normal and binormal vectors T, N, B, and the curvature of the curve
x = 4t, y = -3t^2, z = -4t^3 at t = 1."
Answer:
T = 0.285714285714286 i - 0.428571428571429 j - 0.857142857142857 k
N = -0.75644794981871 i + 0.448265451744421 - 0.476282042478447 k
B = 0.588348405414552 i + 0.784464540552736 j - 0.196116135138184
ϰ = 0.0445978383113072
N = dT/dt / |dT/dt|
I tried to use the equation from the "Relevant equations" part above. I know there are alternative ways but I want to figure out what I am doing wrong for this method.
I (successfully) get the unit tangent vector to be:
T = (4 i - 6t j - 12t^2 k)/sqrt(4^2 + 6^2 * t^2 + 12^2 * t^4)
T = 2/7 i - 3/7 * t j - 6/7 * t^2 k
I (unsuccessfully) get the unit normal vector to be:
N = (3/7 i - 12/7*t k)/sqrt( (3/7)^2 + (12/7)^2 * t^2)
What am I doing wrong?
Any input would be greatly appreciated!
Thanks in advance!
s3a said:
Question:
Answer:
N = dT/dt / |dT/dt|
The above is really T(t), the tangent vector for an arbitrary value of the parameter t.
The problem asks for the unit tangent vector and unit normal vector at t = 1. IOW, it's looking for T(1), N(1), and B(1).
See above. I didn't check your work, so if you have errors, I wasn't looking for them. Again, you want T(1), N(1), and B(1) - the unit vectors at a particular value of t.
Thanks in advance!
When you went from T = (4 i - 6t j - 12t^2 k)/sqrt(4^2 + 6^2 * t^2 + 12^2 * t^4) to T = 2/7 i - 3/7 * t j - 6/7 * t^2 k you put t=1 in the denominator. That's means you can't use the second expression to find dT/dt. You eliminated some of the t dependence. You need to use the first and use the quotient rule. BTW this is quite a messy problem.
Sorry, I was doing a lot of stuff in my head so the t = 1 went on and off.
I get |dT/dt| to be sqrt(144t^4 + 36t^2 + 16) and it doesn't seem that I can get rid of the square root.
So, I am assuming it's hard to do it this way and that I shouldn't do it this way assuming it is possible. Is it possible though? (I am not asking for it computed that way but I would just like to know if it is possible to get past that step without using a computer or something of the sort.)
I get something a LOT messier for |dT/dt|. I'm using a computer for this one and would feel sorry for someone who wasn't. It's pretty bad.
