Find Magnitude & Direction of A+B - Unit Vector Help
To find the magnitude and direction of the vector A + B, first add the components of vectors A = -4i - 1j and B = 8i - 2j, resulting in the vector 4i - 3j. The magnitude of this resultant vector can be calculated using the formula √(x² + y²), yielding a numerical value. To determine the direction, convert the vector from rectangular to polar coordinates, which involves calculating the angle using trigonometric functions. The angle is typically measured clockwise from the positive x-axis. Understanding these conversions is essential for completing the homework assignment correctly.
Loppyfoot
Find the magnitude and direction of A + B for the following vectors.
A = -4 i - 1 j, B = 8 i -2 j
How do I find the magnitude of A+B, and also the degree clockwise from the +x direction?
You add the components to get the resultant, which is also in rectangular coordinates. Do you know how to convert the resultant vector from rectangular coordinates to polar coordinates (so you can get the resultant magnitude and direction)?
So would it be 4i - 3j? On my webassign homework, it has to be a single numerical value.
That's the correct answer in rectangular coordinates. If they are asking for a single number for an answer, did you say they want the angle that the vector forms with some axis? A vector is always made up of 2 numbers (in 2 dimensions). In rectangular coordinates, it's the i and j components. In polar coordinates, it's the magnitude and direction (usually the direction is the angle swinging up from the x-axis to the vector).
Do you know how to convert the vector from rectangular to polar coordinates? That should be in your book.
Got it. Thanks man!
The book claims the answer is that all the magnitudes are the same because "the gravitational force on the penguin is the same". I'm having trouble understanding this. I thought the buoyant force was equal to the weight of the fluid displaced. Weight depends on mass which depends on density. Therefore, due to the differing densities the buoyant force will be different in each case? Is this incorrect?
  • · Replies 16 ·
