Units in a heat transferred calculation
The discussion centers on the calculation of heat transferred using the formula q=mc∆T, specifically focusing on the rearrangement to find the change in temperature (∆T=q/mc). The confusion arises from the units involved, particularly the cancellation of kg and kg-1. Participants clarify that kg multiplied by kg-1 simplifies to kg^0, which equals 1, confirming that the units do indeed cancel out correctly, leading to the final answer in °C.
  • Understanding of the heat transfer equation q=mc∆T
  • Basic knowledge of unit cancellation in physics
  • Familiarity with algebraic manipulation of exponents
  • Concept of specific heat capacity
  • Review the principles of thermodynamics related to heat transfer
  • Study unit conversion and dimensional analysis in physics
  • Learn more about specific heat capacity and its applications
  • Explore algebraic rules for manipulating exponents and units
Students in physics or engineering, educators teaching thermodynamics, and anyone involved in calculations related to heat transfer and energy.
smulc
I'm trying to do a calculation using: Heat transferred = mass x specific heat capacity x change in temperature
q=mc∆T
But the value I'm trying to calculate is the change in temperature so I've rearranged the equation to ∆T= q/mc
I think the numbers and answer I have are correct, but the units are confusing me. My answer clearly needs to be in °C, the joules on the top and the bottom will cancel out but then on the bottom I'm left with kg multiplied by kg-1.
3.54 J
450 kg x 4.2 x 103 J kg-1 °C-1
As far as I know, these don't cancel each other out so my answer has the wrong units. I don't know if I've done the entire thing wrong if I'm just confusing myself over something silly. I'd appreciate any help at all.
smulc said:
... on the bottom I'm left with kg multiplied by kg-1.
So are you wondering what to do with kg·kg-1?
kg is the same as kg+1, so what you really have is kg+1·kg-1. Simplify that using algebra rules for exponents, and you should be all set.
ohh I feel really stupid now. Any number to the zero power is equal to 1. I already knew this but mistakingly thought that the result of calculating kg0 would be 1kg, but the answer is literally just 1, isn't it? So the kg does actually cancel. I feel silly for not realising, thanks very much for the help!
You're welcome, glad it worked out for you.
  • · Replies 16 ·
