Unwinding Spool vs. Standard Block
  • Thread starter Thread starter ssturb
    Block Standard
The discussion centers on the comparison between an unwinding spool and a standard block being pulled by the same tension T on a frictionless surface. Both objects are theorized to cross the finish line simultaneously due to equal acceleration, but the spool possesses greater total kinetic energy (KE) because it combines translational and rotational motion. The additional work done on the spool arises from the unwinding string, which allows the force to act over a greater distance compared to the block. Consequently, while their translational kinetic energies are equal, the spool's rotational kinetic energy contributes to its overall energy advantage.
  • Understanding of Newton's laws of motion
  • Familiarity with concepts of kinetic energy (translational and rotational)
  • Knowledge of tension forces in mechanical systems
  • Basic principles of frictionless surfaces in physics
  • Explore the principles of rotational dynamics and moment of inertia
  • Study the work-energy theorem in the context of mechanical systems
  • Learn about the effects of tension in pulleys and unwinding systems
  • Investigate real-world applications of rotational kinetic energy in engineering
Physics students, mechanical engineers, and anyone interested in understanding the dynamics of rotational and translational motion in mechanical systems.
ssturb
Pulling an Unwinding Spool vs. Standard Block
This problem is done on a frictionless surface
There is a block pulled by a string with tension T.
Next to it, there is a spool with a string wrapped around it and may unwind. It is pulled with the same tension as System A. The spool is standing on its base, so it slides, and doesn't roll.
The question is whether the block or spool will cross the finish line first, which force does more work, and whether the total kinetic energy (trans. + rot.) are equal.
conceptual
They should cross the line at the same time because it shouldn't matter where the force is applied, the object will still accelerate at the same speed. However, the spool should have more total KE because it is spinning and moving when it crosses the finish line, which also means more work is done on it. What I'm confused about is where the extra work comes from. Does the force on the spool do more work because the string is also unwinding, so the force acts over a greater distance than the force acting on the block?
Right! The same force produces the same acceleration of the center of mass.
Right again.
Absolutely right!
Someone pulling the string must do a lot more pulling as the spool unwinds, thus they do more actual work on the spool. That extra work goes into rotational KE.
Does that mean the translational kinetic energy of the block and spool will be the same?
That's right.
  • · Replies 90 ·
