Upgrading Win 7 32 bit to Win 10 64 bit
  • Thread starter Thread starter Wrichik Basu
    Bit Windows 10
37 replies · 8K views · last reply
Insights Author
TL;DR
Some questions regarding upgrading a Windows 7 Professional 32-bit desktop to Windows 10 Professional 64-bit.
We have a Windows 7 Professional 32-bit desktop running on an Intel core i3 processor which is 64-bit capable. No idea why 32-bit version of OS was installed. I want to upgrade it, as stated above. I will be doing this for the first time, so there are some unanswered questions.
I will be using the Windows media creation tool available online. I will also take a full system backup before proceeding.
1. Can I directly upgrade from Win 7 32-bit to Win 10 64-bit? Or should I first upgrade Win 7 to 64-bit, and then to Win 10?​
2. I know that I will have to format some HDD partitions, but which one? Disk Management shows the following:​
Currently the OS is installed in C: drive as usual. D:, E: and G: have user files only. So when I upgrade to 64-bit, do I just format C: drive and leave the rest unaltered?​
I checked YouTube. This video, focusing on upgrading Win 10 32-bit to 64-bit, uses the "Custom" installation option and formats only one partition. (However, I don't know whether the other partitions have other OS, or are used for storing files, like in my case.) Another video, which aims at upgrading Win 7 32-bit to 64-bit, uses the "Upgrade" option instead, and only one partition is shown after that. Upgrading is supposed to preserve personal files, and if I don't format the other partitions, that too should preserve data therein. ∴ Which option?​
3. From the above two videos, it seems that the drives are denoted by "Drive 0 Partition #". Will the drive letters (like C:, D:, etc.) also appear there?​
4. Should I keep System reserved partition as it is?​
5. The PC has Akamai Netsession Interface installed. Neither my father nor I have any idea how it was installed (installed maybe 6 years back). I checked online to find that it is not available for download. I had a small chat with their agent, and they asked me to contact Windows support. I searched through Windows product help forums, and there was nothing useful. Any idea how to reinstall this? Does it come bundled with Windows?​
Any additional advice?
The only good advice I can give you is to clone your disk first.
Then safely you can experiment installing new software.
You will most definitely run into trouble, otherwise.
There is no in-place upgrade from 32- to 64-bit for either Win 7 or Win 10 so normally I would say there is no point doing it in 2 stages, just do a clean install of Win 10 64 bit. However the free upgrade from Win 7 to Win 10 expired about 3 years ago so unless you have paid for a new Win 10 license (in which case you should have instructions and support from whoever you bought it from) then you are trying to do something that is not officially supported. That doesn't necessarily mean it won't work :cool:, but it does mean that you can't rely on it working like it says in any instructions - you're on your own, sorry!
Ignore this, you don't need it.
Why do you assume that I will be doing something illegal (like installing a cracked version)? If I wanted to do that, I would not have posted here, because I know that moderators would soon close my thread in that case.
I will buy the license in January before installing. But they would only give the activation key through email, no physical installation CD.
You are looking at a fresh install, during the initia install phase it will ask you where to install the OS, just select the existing C: drive partition which is thefirst one after the system partition. The system partition contains the boot instructions for Windows and is needed. If you delete it, it and the C: drive it will only get recreated during the install.
You have a puzzling disk configuration there. Having so many partitions on 1 physical disk doesn't really make much sense, you may as well just have 1 big C: drive. If you have a external USB disk of sifficient capacity, I would just copy off all the data from your data drives and then copy it back later after the Windows is installed. That way during the install phase you can delete all the partitions and let Windows create a big C: drive. Your disk si also configured as a Dynamic disk for no reason, it should be a basic disk. Again if you can wipe all the partition Windows will install as a basic disk.
Yes, as I said in the OP:
For me, backup means copying files to an external HDD.
No idea why it was formatted as a dynamic drive. Does it have any advantage over basic disk?
Yeah, I thought about that before. Let's see what I can do.
Backup: Yes copying the data to an external drive is the same thing. Note that we are talking about data here, not part of any installed program. A full system backup would also include the Windows 7 install so you could restore it later via the install media if your upgrade goes wrong.
Disk Type: A dynamic disk is meant to be part of a redundant array of disk (RAID) which you cannot have with just 1 disk. No real difference but changing drive/partition sizes later can be complicated if it's dymanic.
With a fresh install it will be like you just got a new PC, none of your programs / configuration will carry over. If you want to keep things like your browser links you can look at the "User State Migration Tool" from Microsoft. This will copy your local config to your hard disk which you can then restore later.
I didn't assume that at all. It is common knowledge that regardless of what Microsoft's official upgrade policy says, if you download and install Win 10 over Win 7 it might just work anyway: try it!
Well with a new activation key you should have no problems, download and run the installation media and it will detect the old Win 7 32 bit and ask you what you want to do with it. Alternatively follow the tips below and keep your old HD intact...
  • If you can afford it I'd recommend doing a bare metal install on a decent SSD - this will improve performance a great deal and avoid any backup worries.
  • If you can't afford an SSD, I'd recommend doing a bare metal install on a new or repartitioned HD (or a slightly second hand one from a friend that has upgraded - most people I know have a couple lying around) - this will again avoid any backup worries.
  • For a full list of what is installed on your current Win 7, including product keys, download and install Belarc Advisor.
Problem is, it will upgrade it to Win 10 32-bit. For 64-bit, it perhaps has to be a clean install.
The motherboard is Asus P7H55-M LX from 2013. As far as I know, it doesn't support SSD.
Will think about that, thanks for the suggestion.
That's a good software. I created a full system report of the PC with it some months back.
Yes I think you are probably right.
SATA is SATA*, the motherboard only cares about the interface not what is on the other end.
I agree with @MikeeMiracle, there is no point in partitioning a windows desktop so if this was my machine I'd:
  • Unplug the existing HD
  • Do a bare metal install on a new 500 MB SSD
  • Plug the old HD in (while switched off of course) and copy all the data over to the SSD
  • Repartition the old HD to a single partition and do a full reformat to mark dud sectors
  • Copy media files back to the newly formatted HD - this will free up space on the SSD and you won't notice the difference in loading time.
* that MoBo appears to be SATA II whereas most SSD on the market now are SATA III, but there is backward compatibility
pbuk said:
[*]Do a bare metal install on a new 500 MB SSD
GB.
I strongly recommend this approach. SSDs have gotten pretty cheap and they provide a massive performance improvement over spinning platters.
I'm not questioning this statement, but don't know for a fact that it is true. With the past two weeks I upgraded by 6-year old HP with an Intel i7 processor from 64-bit Win 7 to 64-bit Win 10 (Home). I delayed for a long time because I don't care for the so-called Metro interface. It turns out that you can download a free app from http://ninite.com to make Win 10 look like Win 7, but retain the improvements that Win 10 offers.
I missed out on the free upgrade period, and because MSFT is discontinuing support for Win 7, I thought I would not to lay out some $ for Win 10. It turns out that you can still get Win 10 for free (this might be limited to the Home edition, which is missing some features of Win 10 Pro). If you have a legal version of Win 7 or 8, you don't even have to enter a product key. I don't remember the site I used, but here is one I found right now:
https://www.howtogeek.com/266072/yo...ws-10-for-free-with-a-windows-7-8-or-8.1-key/
I was able to upgrade to Win 10 in place - I didn't have to do a clean install. Before I did the upgrade, I did a system backup to an external drive. After the upgrade, I did another system backup.
The whole process went very smoothly, something of a surprise to me. I'm very pleased at how quick and easy it was.
That's because you upgraded from and to 64-bit. Changing word length of OS means a clean install - this is what I learned from the net.
ahhhh no, get into the GB size 250GB minimum
You won't even fit WIN10 on a 500MB drive :wink:
Wrichik Basu said:
Summary:: Some questions regarding upgrading a Windows 7 Professional 32-bit desktop to Windows 10 Professional 64-bit.
...should I first upgrade Win 7 to 64-bit, and then to Win 10?
My advice would be to stay with the Win 7 64-bit (less intrusive than Win 10). My Win 7 64-bit machine also blocks upgrading to Win 10 using the GWX Control Panel tool.
Windows 7 support and (feature and security) updates is coming to an end on January 14, 2020. That is one of the reasons why I want to shift to Windows 10. Why do you call Win 10 intrusive? I have been working on Win 10 in my laptop for a number of months now without any major issue.
Been using Windows 10 for ages, I don't see anything intrusive in it. The main difference is the start menu but most people just "pin" their favourite apps to the task bar so you don't need to use the start menu that often. It's by no means terrible, just different to what came before. Basically just stick to the desktop OS side and don't start messing with Microsoft "apps" from the microsoft store which use the dodgy tablet interface.
Staying on Windows 7 is just asking for trouble due to no security patches being released for it. Your basically asking to get infected by malware. It's the same for those who refuse to update their PC each month.
@dlgoff why do you find it comforting that a piece of software that has been download from an anonymous website without even an SSL certificate tells you "You appear to be safe"? Microsoft may not be perfect, but I know who they are and what motivates them, and that there are organisations with a lot more to lose than I have that ensure that when M$ screw up it is fixed, quick. Until EOL, which is less than a month away for Win 7.
Well, I'm safe from not getting Windows 10.
  • Haha
Why I'm using Windows 7 Professional:
https://www.microsoft.com/en-us/download/details.aspx?id=8002 said:
Windows XP Mode for Windows 7 makes it easy to install and run many of your productivity programs that run on Windows XP directly from a computer that runs Windows 7.
To use an app that presumably hasn't received security patches for the last 10 years? Well, whatever floats your boat, but I'd want to isolate this in a VM without any internet access. And I think you should probably state your reason for using Win 7 when advising anyone else to do the same.
I am planning on an upgrade too. Already backed up important drive on my SSD but Windows Media Creation Tool keeps saying 'the process can not be completed. please try again'. I already did this multiple times, even changed another USB for the task. still no luck. Any better alternative to replace Windows Media Creation tool?
Try running it by right-clicking and selecting "Run as Administrator." It should work fine after that.
I thought I did. "Windows 7 makes it easy to install and run many of your productivity programs that run on Windows XP" Lots of my work involves running several 16 bit applications that only run on XP.
You can trick the program into thinking it is running on a previous verion of Windows.
Right click your programs icon and select properties. In there you will find a compatibility tab. From there you can choose the OS compatibility type, so it could run the program designed for XP as it presents it with the same type of data XP would.
It's not full proof but works most of the time for running older software not designed to run on modern operating systems.
Fortunately we don't have any such apps.
I have forgotten to post one question. While working with my Win 10 laptop, I find there is a hotspot and a VPN feature. In our desktop, there is no internal WiFi adapter; I have bought one external USB adapter, and mainly use it to tether the internet connection of the desktop through Connectify. The question is, when I install Windows 10, will the hotspot and VPN feature also be installed by default, so that I don't have to use Connectify any longer?
Yes, but not well and not at all for my older versions of AutoCAD and AutoSketch.
Don't want to derail the thread, but any specific reason to stick to old version of AutoCAD? Is it related to some license issue? My father uses the latest version in his office on a Win 10 machine, and I never heard him complaining that it doesn't work.
