USB Type-C vs Thunderbolt: Which is faster and better for data transfer?
  • Thread starter Thread starter Stonestreecty
    Ipad Usb
The discussion centers on the comparison between USB Type-C and Thunderbolt ports, specifically in the context of the iPad Pro (1st generation). Thunderbolt is established as technically faster than USB Type-C; however, the performance benefits are only realized when the Thunderbolt connection is directly integrated into the device's motherboard. Users must consider the capabilities of their devices, cables, and adapters, as using an adapter with a lower native speed will result in bottlenecking. Additionally, Apple has limited the iPad Pro's charging cable to USB 2.0, which affects data transfer speeds.
  • Understanding of USB Type-C specifications
  • Knowledge of Thunderbolt technology and its versions
  • Familiarity with data transfer protocols (e.g., USB 3.1, Thunderbolt 3)
  • Awareness of cable types and their impact on performance
  • Research the differences between Thunderbolt 3 and USB 3.1.x specifications
  • Learn about the impact of cable length on data transfer rates
  • Explore compatible devices for Thunderbolt and USB Type-C
  • Investigate the performance implications of using adapters with different port types
Tech enthusiasts, hardware developers, and anyone looking to optimize data transfer speeds on devices with USB Type-C or Thunderbolt ports.
Stonestreecty
TL;DR
For my iPad Pro (1st generation), USB Type-C or Thunderbolt port is better?
Hi,
I have an iPad Pro (1st generation) with what appears to be a USB type-C port. Period. No other ports, which I’ve been trying to get used for for more than a year now, but that’s not my current issue.
Here’s what is the issue:
I figure it out based on Identify USB Types by Its Appearances Support, still confused, I simply want to know which is faster/better, my USB Type-C port or a Thunderbolt port?
I assume there is an appropriate adapter if the answer is Thunderbolt? :oldconfused:
Computer science news on Phys.org
To get the maximum speed of any port it needs to be native on your device and wired into the motherboard. If you have a port capable of say 1GB transfer rate, and you plug an adapter to it that is natively 10GB transfer rate, then that adapter still plugs into the 1GB port so you will only get 1GB as that is your bottleneck.
I would just buy devices that are compatible with whatever port you currently have.
Thunderbolt is technically faster but you won't see the benefit without it having direct access to your motherboard.
Likes DaveE, berkeman and phinds
True.
When gathering gear, people need to consider the protocols and abilities of not only the device's port, but also the cables', hub's/dock's/..., and those of the target device. various cables, each optimized for different chores. While power/charing cables can be long, high speed data transfer protocols (read: TB3, USB3.1.x) abhor long cables.
It appears that Apple chose to only support USB2.0 on the charging cable supplied with the new iPPs. It was, perhaps, done to balance the size of the power conductors needed with their manic drive for "thin" and/or to allow for a longer cable. USB3.x and TB3 require more data lines, leading to bulkier cables, and can have issues with longer cables.
  • · Replies 0 ·
  • · Replies 16 ·
90K
  • · Replies 19 ·
14K
