Use comparison theorem to show if integral is convergent or divergent
The integral of (e^-x)/(x) from 0 to infinity is an improper integral that requires the application of the comparison theorem to determine its convergence or divergence. The discussion highlights the necessity of breaking the integral into two parts: from 0 to 1 and from 1 to infinity. It is established that the integral from 0 to 1 diverges due to the behavior of the function 1/x, which diverges at both limits. Thus, the overall integral is concluded to be divergent.
  • Understanding of improper integrals
  • Familiarity with the comparison theorem in calculus
  • Knowledge of basic integration techniques
  • Concept of convergence and divergence of integrals
  • Study the comparison theorem in detail with examples
  • Learn about improper integrals and their evaluation techniques
  • Explore the behavior of functions like 1/x and e^-x in integrals
  • Investigate other convergence tests for integrals, such as the limit comparison test
Students studying calculus, particularly those focusing on improper integrals and convergence tests, as well as educators looking for examples to illustrate the comparison theorem.
zero13428
int (e^-x)/(x)dx from 0 to infinity
Determine if integral is convergent or divergent2. The attempt at a solution
I assume because the bottom limit is 0 and there is an x in the bottom of the integral that this is going to be divergent but I still have to use the comparison theorem. I'm trying to find a function less then (e^-x)/(x) that also diverges to show that (e^-x)/(x) will diverge but I'm drawing a blank. I've tried messing around with 1/x^2 or just e^-x but both of those are still larger then the original (e^-x)/(x). Any suggestions?
1/x is an interesting function in that it diverges both ways, the integral from 0 to 1 of 1/x is divergent, as is the integral from 1 to infinity (compare this to x^{1/2} and \frac{1}{x^2}). So when trying to do comparison with a 1/x term, it often helps to break up the integral into one from 0 to 1 and one from 1 to infinity, and see on each of those whether it converges or diverges
Ok, so if I can break the function into two parts, as long as one part (in this case 1/x) converges or diverges then the entire function does?
I thought I could only do these type of integrals by picking a function that was larger or smaller and then comparing.
Since this is an improper integral at both limits of integration, that's why you should consider the two intervals (0, 1] and [1, ∞) separately. Try finding whether the integral from (0, 1] converges first.
  • · Replies 16 ·
