Evangeline101
- 112
- 5
Evangeline101 said:Homework Statement
View attachment 101055Homework Equations
[/B]
Back again :) Is this correct?
Thanks.
Ray Vickson said:In thread after thread you ask "is this correct?...". That is a bad habit: as a matter of standard operating procedure you should check your answers for yourself (as you would need to do in an exam setting). Then, if you find something does not "work", you will know you have made an error somewhere, and asking for help then makes sense.
Evangeline101 said:I understand, but can you suggest a less time consuming method than graphing, if I am doing an exam I won't have time to graph anything to check my answer. For this specific question, is there a way I can put the points back into the equation to verify, well maybe in this case I would have to graph since they are points of intersection.
Also I should be more clear when asking my question ( I will make sure to do that in future questions), in this case I would like to know if my process for part b is correct, does it make sense to use the linear equation to solve for y-values, and if so, is it because the linear equation is set equal to y?
Sure. You can substitute the points you found into each equation. If the point is on the graph, the equation should be a true statement.Evangeline101 said:I understand, but can you suggest a less time consuming method than graphing, if I am doing an exam I won't have time to graph anything to check my answer.
Evangeline101 said:For this specific question, is there a way I can put the points back into the equation to verify, well maybe in this case I would have to graph since they are points of intersection.
