Use Residue Theorems or Laurent Series to evaluate integral
The discussion revolves around evaluating the integral ∫C (z^10) / ((z - (1/2))(z^10 + 2)) along the contour C defined by |z| = 1. The subject area includes complex analysis, specifically residue theorems and Laurent series.
  • Participants explore rewriting the integrand and consider using Laurent series expansion. Questions arise regarding the identification of poles and their locations, particularly focusing on the pole at z = 1/2 and the implications of the other factor in the denominator.
Participants are actively discussing the identification of poles and the methods for evaluating the integral. Some have attempted to apply the Cauchy integral formula, leading to different interpretations of the problem. There is an ongoing exploration of the implications of complex roots and the nature of the integrand.
Participants note that the problem is not limited to residue theorems and Laurent series, indicating a broader scope for potential methods of solution. There is also a mention of the complexity involved in dealing with fractional powers in the context of complex numbers.
monnapomona
Evaluate the integral using any method:
C (z10) / (z - (1/2))(z10 + 2), where C : |z| = 1​
C f(z) dz = 2πi*(Σki=1 Resp_i f(z)
Rewrote the function as (1/(z-(1/2)))*(1/(1+(2/z^10))). Not sure if Laurent series expansion is the best choice for this problem but I ended up getting: (Σn=0 (1/2)n / zn+1)*(Σn=0 (-1)n 2n/(z10)n)
I get stuck at this point but i tried working out the series and get: 1 - 2/z12 + 1/z23+ ...
So would the residue just be 1 and the ∫C f(z) dz = 2πi?
**sorry in advance for my formatting**
What are the poles and where are they located?
Not sure if this is correct but would one pole be +1/2 (Used this function (1/(z-(1/2))) for my reasoning)?
You just need to find where the denominator vanishes, so ##z=1/2## is definitely one pole. Where are the rest?
That's where I'm kind of stuck. For the other function in the denominator, (1/(1+2/z^10)), it doesn't go to 0 even if z = 0?
Oh, look at the integrand before you messed with it. In other words, when does the denominator of ##\frac{z^{10}}{(z-1/2)(z^{10}+2)}## vanish?
Would the poles be z = 1/2, (-2)^(1/10) ?
Expand on what you mean by (-2)^(1/10). Remember, you're working with complex numbers, so taking fractional powers is a little more involved. Consider solving the equation ##z^{10} = -2e^{2\pi n i}## where ##n \in \mathbb{Z}##.
Went to office hours today, it turns out for this question, it wasn't limited to just the residue theorems and Laurent series expansion methods. I tried using Cauchy integral formula, where z0 = 1/2 and f(z) = (z^10 / (z^10 + 2)) and got 2πi / 2049 as the final answer.
Regardless of which method you end up using, you still need to determine where the poles are. Just make sure you know how to do that.
The number ##-2## has ten 10th roots!
