Use Stokes Theorem to show a relationship
18 replies · 4K views
princessme
Use the Stokes' Theorem to show that
[itex]\int[/itex]f(∇ X A) dS = [itex]\int[/itex](A X ∇f) dS + [itex]\oint[/itex]f A dl
Use vector calculus identities. Hint given : Start with the last integral in the above relation.
To be honest, I really don't know how to start doing this. I could understand Stokes theorem when needed to evaluate the circulation, vector and surface, but I don't have any idea on how to start to prove this relation. Please help?
Do you know any identities? What does stokes theorem state?
Did you know that by convention ##\mathbf n dS## is the same as ##d\mathbf S##?
So what do you get if you set ##\mathbf F = f \mathbf A## and ##\mathbf r = \mathbf l##?
Is there another identity on your web page that you can apply then?
Sorry but I still don't get it..quite confused. How should I actually begin proving it?
princessme said:
Sorry but I still don't get it..quite confused. How should I actually begin my proving it?
Start with [itex]\oint[/itex]F.dr = [itex]\int[/itex]∇ X F . dS
What do you get if you substitute ##\mathbf F = f \mathbf A## and ##\mathbf r = \mathbf l##?
I'll get [itex]\oint[/itex]fA.dl = [itex]\int[/itex]∇ X F . dS
Good!
But there's still an ##\mathbf F## in there.
Can you replace that too?
I like Serena said:
Good!
So it will be [itex]\oint[/itex]fA.dl = [itex]\int[/itex]∇ X fA . dS
Right!
Actually, let's make that [itex]\oint[/itex](fA).dl = [itex]\int[/itex]∇ X (fA) . dS
Do you have another identity on your web page for something like that?
Perhaps something like ##\nabla \times (u\mathbf A)##?
I like Serena said:
Right!
Okay!
Yeah ∇ x (uA) = u∇ x A - A x ∇u
princessme said:
Okay!
Good!
Substitute?
I like Serena said:
Good!
Substitute?
[itex]\oint[/itex](fA).dl = [itex]\int[/itex] (u∇ x A - A x ∇u ) dS ?
I can see where is this going now..But the original form they wanted is f(∇ x A) dS . so u∇ x A dS is equivalent to that form?
Yes.
You were supposed to replace u by f as part of the substitution.
I like Serena said:
Yes.
alright. So the it doesn't matter that the f in the original form is outside the bracket and not just stuck with ∇?
In this case it doesn't matter. Both forms are the same.
But as a rule, you should read ##f\nabla \times \mathbf A## as ##f(\nabla \times \mathbf A)##.
Okay thank you for the great help!
Hi there. I have another question. I realized that I made a mistake on my Stokes' Theorem equation at first. The surface integral should be a double integral. But for the one that I need to prove, it is just a single integral. Will that make any difference to my answer?
That's not really a mistake.
You are integrating with ##d\mathbf S## which is an infinitesimal surface element.
You can either use one or two integral symbols - it means the same thing.
Formally, it should be a single integral symbol, since there is only one infinitesimal specified.
It should only be a double integral if your integrating with the infinitesimals ##dx dy## or some such.
