Using a puley for analysis on an air track?
The discussion revolves around using a pulley system with a data logger to analyze motion on an air track, specifically for an experiment on collisions involving momentum and energy. The user faces challenges with drag from the pulley setup and interference from the wire connected to the data logger, which affects the trolley's movement. Suggestions include using a strobe light and camera for accurate measurements or attaching the trolley to a string tied to a pivot to minimize interference. The user aims to record distance versus time or velocity versus time for one cart before and after collisions. The experiment focuses on understanding kinetic energy and momentum dynamics.
Atlaπtis
using a puley for analysis on an air track?
I'm doing an experiment using an air track, and my school only has one photogate/lightgate. So I'm trying to figure out a way of using the pulley (not an actual pulley, one that is used with a data logger to record time and velocity) without it effecting the experiment...We have tried heaps of different ways but all the things we have done have either added too much drag to the air track trolley thing so it hasn't been able to move freely or the wire of the pulley has interfered (as it's connected to the data logger) and it has pulled the trolley down the track...so I'm stuck...Anyone got any ideas?? Or know of any other way we can measure the trolleys?
(by the way, my experiment is to do with collisions (momentum and energy))
What about a strobe light and a camera? Would that be accurate?
If your air track is an air table. then you could attach the trolley to a string which is tied to a pivot in the center of the table. Then a single photogate can record the transit time around the circle. Because the force of the string is perpendicular to the trolley's velocity, it should not change it.
Nah, it's just a normal air track
What data logger are you using?
What specific data do you want to record--pos. vs. time for one cart, for each cart, separation between the carts vs. time...?
To be honest, I actually don't remember what it said on the top of the data logger. It's one of the ones that are hooked up to a computer, and it's used with a program called Tainlab WinTec. I'm on the programs website and I'm pretty sure it's the TecMaster.
What I am looking to record is the distance vs time or velocity vs time for one cart just before the collisions and then for the other cart just after the collision (the second cart will be stationary). The experiment I am trying to do is about kinetic energy and momentum
comparing a flat solar panel of area 2π r² and a hemisphere of the same area, the hemispherical solar panel would only occupy the area π r² of while the flat panel would occupy an entire 2π r² of land. wouldn't the hemispherical version have the same area of panel exposed to the sun, occupy less land space and can therefore increase the number of panels one land can have fitted? this would increase the power output proportionally as well. when I searched it up I wasn't satisfied with...
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
