Using Cross-Product and Vectors to find the distance between parallel lines ?
The discussion centers on understanding the use of the cross-product in determining the distance between two parallel lines. The cross-product provides a vector that is perpendicular to the lines, which is essential for calculating the distance. The formula presented relates the magnitude of the cross-product to the sine of the angle between the vectors, illustrating how to visualize the relationship with a triangle formed by the vectors. A diagram depicting the parallel lines and the relevant points helps clarify the geometric interpretation of the distance. Overall, the explanation emphasizes the geometric principles underlying the calculation of distance between parallel lines.
Beamsbox
Given the following two lines, prove that they are parallel, then find the distance between them...
(I have circled in red the two parts of the answer which I don't understand. Namely, why are they using the cross-product here, doesn't that give you a value perpendicular to the lines, hence a new vector that is on the parallel planes of the lines? The second part I highlighted I have no idea why they chose this.)
Could someone please explain the reasons to me? Something that I could visualize would be helpful.
Thanks, prior!
Remember the formula
\| \vec{AP}\times\vec{AB}\| =\|\vec{AP}\|\|\vec{AB}\|\sin(\theta)
so your formula results in
\|\vec{AP}\|\sin(\theta)
Draw a picture of two parallel lines and label A,P, and B and the angle θ between the vectors AP and AB. If you draw a perpendicular line between the vectors you will see that is its length by looking at the triangle with θ the angle between the two vectors.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
