Using Different Versions of Python - Compatibility/Dependencies?
  • Topic: Python
  • Thread starter Thread starter WWGD
    Python
54 replies · 8K views · last reply
Homework Helper
Hi All,
I am trying to learn versions 2,3 of Python ( long story). Just curious as to the "Dependency/Compatibility" issues between and within versions 2 and 3. Are packages/libraries in 3.x available for 3.x' where x'>x ? How about for version 2? Specifically, at this point, I am trying to do some Web Scraping. If I learn to use it with one version, how likely am I of being able to do the same or similar within an other
I am fairly new to Python also. I chose to go with 3 right away and a lot of examples use 2. However, I haven't had too many issues using version 2 examples with my version 3 code.
Have you been able to do Web Scraping with more than one version?
Haven't done that. I've been focused on machine learning code.
And you have been able to go back-and-forth between versions?
EDIT: Do you use Graphlab or something else for ML?
I haven't been doing that. I just said that I've had few problems using the version 2 examples in my version 3 environment. BTW, why do you want to use both versions anyway? I could understand if you had a large collection of version 2 code that you built but, if you're as new to Python as I am, you're better off just going with the newer version.
I agree, it is just that I have seen jobs that look interesting that require 2 , some require 3. Just covering my bases. I will start with 2 with Anaconda, I guess, in the meantime become familiar with 3 and IDLE. What IDE do you use?
If I saw a job that required version 2, that would tell me that they have a lot of legacy code that they need to maintain. Call me silly but I wouldn't want to be a janitor. :oldtongue:
As for my IDE, I've been coding everything in Jupyter.
Do you have access to Graphlab? SFrames? How do you code, e.g., a regression without them?
Borg said:
Haven't heard of that.
So you just code, say a a regression without any additional packages? Sorry if I am being ignorant here, but I have to import other packages before doing any ML
I'm using pip and conda installs to download everything locally. Keep in mind that I'm still learning Python and I'm not dealing with gigantic data sets at this point. My focus is on learning the details of ML algorithms and there's plenty I can do on a laptop for now.
Borg said:
I'm using pip and conda installs to download everything locally. Keep in mind that I'm still learning Python. I'm not dealing with gigantic data sets at this point. My focus is on learning the details of ML algorithms and there's plenty I can do on a laptop for now.
Ok, I do things in a kind of disorganized way, bottom-up learning from a source, top-down by reading someone else's code and eventually comes together in my brain.
Sorry, don't mean to drag this too long, but, would you consider any version of Python 3 before the latest, e.g., 3.4 instead of 3.7?
If I needed to. I was using 3.6 for a while.
I have done web scraping with BeautifulSoup in both Python 2 and Python 3. There isn't much difference between the two. The kind of code you will need to write for web scraping will be pretty much the same in both versions.
https://pypi.org/project/beautifulsoup4/
One key difference is the divide operator. In 2 its returns ints if given ints but in 3 it returns floats. You must use the // to integer divides. // is complementary to % for modular math.
Thanks. That also reminds me of the difference between raw input in 2 and input() in 3.
jedishrfu said:
I would suggest using 3 and not 2 unless the project calls for using 2 for legacy support.
Thanks, but, what then, must one then move on to the next version/generation -- I guess Python 4 -- and so on indefinitely?
This is the common issue developers always face ie use the latest or stick with what works. For major changes you have to weight program life with support for version it uses vs upgrading.
Eventually, but not on any short time scale. Python 2.7, the last version of Python 2, was first released in 2010; Python 2 itself was first released in 2000; and the Python 2 series is being end of lifed by the core developers in 2020. So you're looking at 10 to 20 years between having to switch versions.
This is a philosophical objection I have to Python as a scripting language, versus Perl. The Perl philosophy is "there are many ways to do it" and they try to accept any syntax where they can understand the intent. The Python philosophy seems to be "this is the perfect way to do it and you must comply". That is until the next version comes out and the new philosophy is "this is the new super-duper, perfect way to do it and the old way was TERRIBLE and unacceptable." The Python changes sometimes require rewrites. The changes I needed to make to decades-old Perl scripts were minimal.
This has never been the Python philosophy. The Zen of Python has this:
"There should be one—and preferably only one—obvious way to do it."
Although Tim Peters couldn't resist following that with this:
"Although that way may not be obvious at first unless you're Dutch."
But in any case, nothing requires you to do it the obvious way.
[1] https://en.wikipedia.org/wiki/Zen_of_Python
Within a given Python version (2 or 3), I'm not aware of any change that made a previous way to do it no longer doable. Plenty of changes opened up new ways to do things, but those never invalidated the old ways.
The Python 2 to Python 3 change certainly did break a lot of old ways of doing things, but that was on purpose and the Python devs were quite open about that for years in advance. Also, Python 2 has stayed around and fully supported for 10 years while Python 3 was refined.
Do you have an example within a single Python version (2 or 3)?
Now Scala took this approach resulting in nearly every new version requiring code changes to keep up with the syntactic and semantic changes happening in the language. To be fair, Scala is relatively early in its gestation and is still evolving to become the "perfect" programming language better than Java.
Meanwhile developers move on to more practical languages such as Kotlin or clojure (lisp anyone?) as a means to improve coding performance and expressive power of the language.
Python is a very good language and supersedes Perl in so many ways. But its hard to just make the switch unless you're always looking for the "perfect general purpose" language like me. I preferred C over C++ and Java over both, Groovy over Java and like Kotlin a lot. However, my all time favorite is AWK but I would quickly hit roadblocks due its limitations and programming model and I would happily spend endless hours overcoming them until finally biting the bullet and converting my scripts to Python.
In my experience, I don't see Python restricting my programming at all unlike say Prolog or Lisp or even using in a purely functional programming model which really restricts what you can and can't do but sure makes your code so much easier to debug.
Not within versions, just from 2 to 3.
I have converted some Python scripts, programmed by advocates who were very good programmers. The Perl version was much shorter, easier, and more complete because it is set up very well to invoke OS commands, capture the output into Perl variable, parse, and move to the next step. The reduction in lines, including better error checking, was significant.
Ok. Yes, as I said, there were many backwards incompatible changes from Python 2 to Python 3, but that was made clear for years in advance by the dev team, and they have continued to support Python 2 through the entire process. Only now, when Python 3 is very mature, are we reaching the point where Python 2 will be end of lifed by the core dev team; and even then there will be a further period when others, such as some Linux distributions, will continue supporting it.
Plus, from minor version to minor version in Python 3, just as with Python 2, no incompatibilities were introduced, so code that was written years ago for an early Python 3 version still runs on today's latest Python 3 version. So backwards incompatible changes are very rare with Python, since they only happen with major version changes, and those are very rare (Python 2's total lifetime, as I've said, is about 20 years).
I don't doubt that there are plenty of cases where this will happen. I also don't doubt that there are plenty of cases where the opposite is true, that the Python version of some particular code will be much easier to deal with than the Perl version. It will depend on what particular task you are trying to do (if you're invoking OS commands and parsing the output, then Perl, which is much closer to shell in this respect, will probably be more concise, yes). It will also depend on your own personal preferences, as well as who else will have to deal with your code.
