Using Noether's theorem to get a constant of motion
81 replies · 10K views · last reply
Please let me use Einstein's notation from now on.
Orodruin said:
But you have not shown that translation is a symmetry. This is absolutely necessary in order to use Noether’s theorem.
OK so you're asking to show that
$$L(q^{\lambda}, \dot q^{\lambda}, t) = L(q, \dot q, t)$$
The given Lagrangian is:
$$L = G_{ab} \dot q^a\dot q^b$$
The translation is:
$$q^a \to q^a + \lambda$$
If we take the derivative with respect to time on both sides we get
$$\dot q^a \to \dot q^a$$
The above justifies that ##\dot q^a## terms do not change under translation.
But we are not done yet because ##G_{ab}## depends on ##q##. Thus we still have to show that:
$$G_{ab}(q^c) = G_{ab}(q^c + \lambda)$$
But how? ... (we would have assumed the above to be true in class, but let's show it).
Orodruin said:
What do you need ##dq^a/d\lambda## to be to reproduce the correct constant of motion?
What I know is that ##dq^i/d\lambda## equals to the Kronecker-Delta function, because when we take ##dq^a/d\lambda## on ##q^a \rightarrow q^a + \lambda## we end up with ##1## while taking ##dq^b/d\lambda## on ##q^b \rightarrow q^b## yields ##0##.
My point is that, if I the above reasoning is OK, how can the following derivation be wrong?
$$\frac{\partial (q^a)^{\lambda}}{\partial \lambda} |_{\lambda=0} = 1$$
$$\frac{\partial (q^b)^{\lambda}}{\partial \lambda} |_{\lambda=0} = 0$$
$$\frac{\partial (q^c)^{\lambda}}{\partial \lambda} |_{\lambda=0} = 0$$
$$Q_{q^a} = 2G_{ia} \dot q^i $$
Note I have used ##i## as the dummy index.
Orodruin said:
You cannot just assume that a given transformation is a symmetry.
That's the right way to proceed, indeed.
Please note: this thread may be becoming too long so I would perfectly understand if the best is to stop.
JD_PM said:
But we are not done yet because GabGabG_{ab} depends on qqq. Thus we still have to show that:
Gab(qc)=Gab(qc+λ)Gab(qc)=Gab(qc+λ)​
But how?
In general you cannot because it may not be true. That is the entire point. You need to choose a transformation for which the Lagrangian is invariant. You cannot just choose any transformation. The translation you have chosen is not going to be a symmetry for most Lagrangians.
Could we please postpone the prove that ##G_{ab}(q^c) = G_{ab}(q^c + \lambda)## holds and just assume by now that ##q^a \to q^a + \lambda## is a symmetry of the given Lagrangian?
I would like to focus on the computation of ##dq^a/d\lambda##, which is my big struggle.
What I propose is the test and error method; we assume that ##q^a \to q^a + \lambda## and see if we get the given constant of motion out of Noether's Theorem
JD_PM said:
What I propose is the test and error method; we assume that qa→qa+λqa→qa+λq^a \to q^a + \lambda and see if we get the given constant of motion out of Noether's Theorem
You won’t because your symmetry needs to be based on the relevant Killing field. Without that, how do you suppose the Killing field would end up in the conserved quantity?
JD_PM said:
I would like to focus on the computation of dqa/dλdqa/dλdq^a/d\lambda, which is my big struggle.
By definition of a continuous transformation these are the components of the vector field generating the transformation. There is nothing else to it.
I think I need a better understanding of what's a Killing vector field. I will study more about it.
Thank you for your help Orodruin! :)
That the field is a Killing field really does not have much to do with things at this moment. It will only be relevant in showing that the given transformation indeed is a symmetry of the action. What is relevant at this point is that you understand how a vector field (any vector field) generates a transformation through its flow, i.e., the integral curves of that vector field maps a point in the manifold curves in the manifold in such a way that the vector field is tangent to the curves everywhere. If the curve parameter is ##\lambda## and the field has components ##X^a##, then the tangent at curve parameter ##\lambda = 0## is given by
\left.\frac{dq^a}{d\lambda}\right|_{\lambda=0} = X^a.
Thank you for the explanation. I think that I should work out an example to understand it better. For instance, let's go back to the simplest Lagrangian I brought to the table back in #21
$$L = \sum_{i = 1}^{n} (\dot q^i)^2$$
Could you please explain your argument above based on this specific example I know how to work out? If I see it applied I think I may understand it better.
Instead of that Lagrangian, let us consider the two-dimensional case, and instead of translations, let us consider rotations (to get your mind away from fixating on translations, which I believe is stopping you from reaching insight).
The 2D Lagrangian of relevance is
L = \dot x^2 + \dot y^2.
We can add a rotationally invariant potential term to this, but let us keep from doing that at the moment.
A rotation is defined by ##x \to x \cos(\lambda) + y \sin(\lambda)##, ##y \to -x\sin(\lambda) + y \cos(\lambda)##. The components of the tangent vector field to this rotation is given by taking the derivative with respect to ##\lambda##:
v^1 = \left.\frac{dx}{d\lambda}\right|_{\lambda = 0} = y, \qquad
v^2 = \left.\frac{dy}{d\lambda}\right|_{\lambda = 0} = -x.
The vector field generating rotations is therefore given by ##\vec v = d\vec x/d\lambda = y\vec e_1 - x \vec e_2##. Note that, ##\lambda##, ##\vec x \to \vec x + \lambda \vec v + \mathcal O(\lambda^2)##.
Is this a symmetry of the action? The time derivative of ##\vec x## transforms as
\dot{\vec x} \to \dot{\vec x} + \lambda \dot{\vec v} + \mathcal O(\lambda^2).
It follows that
L = \dot x^2 + \dot y^2 = \dot{\vec x}^2 \to [\dot{\vec x} + \lambda \dot{\vec v} + \mathcal O(\lambda^2)]^2
= \dot{\vec x}^2 + 2\lambda \dot{\vec x} \cdot \dot{\vec v} + \mathcal O(\lambda^2).
We find
\dot{\vec x} \cdot \dot{\vec v} = (\dot x \vec e_1 + \dot y \vec e_2) \cdot (\dot y \vec e_1 - \dot x \vec e_2)
= \dot x \dot y - \dot y \dot x = 0
and thus
L \to L + \mathcal O(\lambda^2).
Thus, the derivative of the Lagrangian is zero at ##\lambda = 0## (and therefore everywhere) and it follows that the rotations indeed are a symmetry of the action.
The corresponding conserved quantity is given by
Q = \vec v \cdot \vec p = (y\vec e_1 - x \vec e_2) \cdot 2(\dot x \vec e_1 + \dot y \vec e_2) = 2(y\dot x - x \dot y),
which in essence is angular momentum. Since our transformation was a symmetry of the action, angular momentum is conserved.Edit: Note that you could start from ##d\vec x/d\lambda = \vec v## with ##\vec v## given by the expression above and integrate this to find the (finite) transformation. However, to show that rotations are a symmetry, we only needed the infinitesimal transformations.
  • Love
Thank you for posting this example; it is what I needed to move forward :smile:
OK so I am going to use your structure. I will work out the translations.
We consider the Lagrangian
$$L = G_{ab} \dot q^a\dot q^b $$
We could add a translationally invariant potential term to the Lagrangian but let's stick to the given problem, which lacks of it.
Translation is given by:
$$q^a \rightarrow q^a + \lambda$$
The components of the tangent vector field to this translation are given by taking the derivative with respect to ##\lambda##
$$k^a = \left.\frac{dq^a}{d\lambda}\right|_{\lambda = 0} = 1, \qquad k^b = \left.\frac{dq^b}{d\lambda}\right|_{\lambda = 0} = 0$$
Thus, the vector field generating translations is given by:
$$\vec k = d\vec q^a/d\lambda = \vec e_1$$
We note that:
$$\vec q^a \to \vec q^a + \lambda \vec k + \mathcal O(\lambda^2)$$
We now check translational symmetry. Taking the derivative with respect to time of the above equation:
$$\dot{\vec q^a} \to \dot{\vec q^a} + \lambda \dot{\vec k} + \mathcal O(\lambda^2)$$
It follows that (note that the derivative with respect to time of ##\vec k## is zero; ##\lambda \dot{\vec k} = \lambda (0) =0##):
$$L = G_{ab} \dot{\vec q^a}\dot{\vec q^b} = G_{ab} \Big( \dot{\vec q^a} + \lambda \dot{\vec k} + \mathcal O(\lambda^2)\Big) \Big( \dot{\vec q^b} + \lambda \dot{\vec k} + \mathcal O(\lambda^2)\Big) = G_{ab} \dot{\vec q^a}\dot{\vec q^b} + \mathcal O(\lambda^2) $$
Thus:
$$L \to L + \mathcal O(\lambda^2)$$
Thus we have shown that the translations indeed are a symmetry of the action.
Now it is time to get the constant of motion ##p_ak^a##
We already computed ##p_a##
$$p_a = 2 G_{ba} \dot q^b$$
Thus:
$$Q = p_ak^a = 2 G_{ba} \dot q^b$$
Mmm we are almost there! I am still missing the Killing vector ##v^a## term. Well, as this quantity (which turns out to be the momentum) is conserved, could we simply multiply ##v^a## on both sides as follows?
$$2 G_{ba} \dot q^b=0$$
$$v^a G_{ba} \dot q^b=(v^a)0$$
Thus we get (note I've dropped the scaling factor):
$$Q_v = v^a \dot q^b G_{ab}$$
Note I have not used
$$\partial_a G_{bc}v^a + G_{ba}\partial_c v^a + G_{ca}\partial_b v^a = 0$$
Mmm I should have used it while checking that translation is a symmetry of the Lagrangian...
I am thinking...
EDIT: I see no mistake in my reasoning on why translations are a symmetry of the action.
Please let me know if I am wrong .
PS: This is so fun!
qa→qa+λ​
First of all, this is a very particular translation, adding ##\lambda## to each coordinate. It is not the transformation we want. Instead, you should be looking at the infinitesimal transformation as I did above:
Orodruin said:
##x \to \vec x + \lambda \vec v + \mathcal O(\lambda^2).##
but with a suitably chosen vector field ##v^a##. This will generally not be a coordinate translation just as the rotation above was not.
JD_PM said:
The components of the tangent vector field to this translation are given by taking the derivative with respect to λλ\lambda
ka=dqadλ∣∣∣λ=0=1,kb=dqbdλ∣∣∣λ=0=0​
a and b are just arbitrary indices that can take any value. You cannot have ##k^a\neq 0## and ##k^b = 0## at the same time.
You have also assumed that ##G_{ab}## does not depend on the coordinates when you wanted to check the invariance of the action, which generally is wrong (if it does not you will have translational symmetry in all directions but this is not what is relevant to this problem).
I get your point. You mean:
$$q^a \rightarrow q^a + \epsilon k^a$$
I see. So:
$$k^1 = \left.\frac{dq^1}{d\lambda}\right|_{\lambda = 0} = 1, \qquad k^2 = \left.\frac{dq^2}{d\lambda}\right|_{\lambda = 0} = 0$$
OK so:
$$L = G_{ab}(q) \dot{\vec q^a}\dot{\vec q^b} = G_{ab}(q+\epsilon k^a) \Big( \dot{\vec q}^a + \lambda \dot{\vec k} + \mathcal O(\lambda^2)\Big) \Big( \dot{\vec q^b} + \lambda \dot{\vec k} + \mathcal O(\lambda^2)\Big) = G_{ab}(q) \dot{\vec q^a}\dot{\vec q^b} + \mathcal O(\lambda^2)$$
But we still have to prove that (where I got stuck back in #31):
$$G_{ab}(q^a) = G_{ab}(q^a+\epsilon k^a)$$
I know it follows from equation ##(2)##; but how?
Unfortunately I need another hint for this one...
I've not followed the entire discussion, which I find very hard to understand. Here are nevertheless some thoughts. I use analytical mechanics as described by the Lagrangian version of Hamilton's action principle with the action given as
$$S[q]=\int_{t_1}^{t_2} \mathrm{d} t L(q,\dot{q},t),$$
where ##q=(q^k)## are arbitrary generalized coordinates.
In Noether's theorem one considers continuous transformations of the form
$$t'=t'(t,q,\dot{q}), \quad q'=q'(t,q,\dot{q}).$$
Such a transformation is called a symmetry, if the variation of the action is invariant, from which after some calculations involving infinitesimal transformations
$$t'=t+\epsilon T(t,q), \quad q'=q + \epsilon Q(t,q)$$
and evaluating the symmetry condition to first order in ##\epsilon## follows that there must exist a function ##\Omega(q,t)## such that
$$Q^k \frac{\partial L}{\partial q^k}+ \left (\frac{\mathrm{d} Q^k}{\mathrm{d}t} -\frac{\mathrm{d} T}{\mathrm{d}t} \dot{q}^k \right)\frac{\partial L}{\partial \dot{q}^k} + L \frac{\mathrm{d} T}{\mathrm{d} t} + T \frac{\partial L}{\partial t} + \frac{\mathrm{d} \Omega}{\mathrm{d} t}=0, \qquad \text{(SC)}$$
where ##\mathrm{d}/\mathrm{d} t## denotes the total time derivative with ##q^k## taken as functions of ##t## and ##\partial_t=\partial/\partial_t## as the time derivative concerning the explicit time dependence (with the ##q## and ##\dot{q}## held fixed).
Looking now at the solutions of the equations of motion,
$$\dot{p}_k=\frac{\partial L}{\partial q^k}, \quad p_k=\frac{\partial L}{\partial \dot{q}^k},$$
this symmetry condition implies that
$$\frac{\mathrm{d}}{\mathrm{d} t} (Q^k p_k - T H+\Omega)=0, \qquad \text{(CE)}$$
where
$$H=p_k \dot{q}^k-L$$
is the Hamilton function of the system.
So to apply Noether's theorem just consider your case. Here you obviously check the special case of "point transformations" only, i.e., a change in the generalized coordinates only, i.e.,
$$Q=v(q)$$.
Now, using your Lagrangian, just derive what follows from the symmetry condition (SC) for the ##v^k## and then use the conservation equation (CE) to get what's the corresponding conserved "Noether quantity".
Thank you for your post vanhees71, I will read it carefully.
I perfectly understand you.
Notice I have been trying to approach the problem and had several misconceptions that Orodruin kindly has been correcting.
I think you can get the picture of where I am at this point only having a look at #40 and #43. I am only missing showing that the symmetric matrix ##G_{ab}## doesn't change under translation
Please let me know if you wish if there's anything in particular you do not understand from my posts.
That condition would mean that all matrix elements don't change along a certain direction, given by the vector ##k^a## (supposed these ##k^a## are constant). Then it's simply translational invariance, and the canonical momentum in this direction is conserved, because from your Lagrangian it follows that
$$k^a \frac{\partial L}{\partial q^a}=0 \; \Rightarrow \; k^a \dot{p}_a=0 \; \Rightarrow \; k^a p_a=\text{const}.$$
In your case
$$p_a = \frac{\partial L}{\partial \dot{q}^a}=2 G_{ab} \dot{x}^b$$
and thus indeed for this special case of a symmetry
$$G_{ab} k^a \dot{x}^b=\text{const}.$$
That's of course not the most general case asked for in your question in #1, which asks for possible symmetries under point transformations, leading to the Killing vectors of the metric ##G_{ab}## under consideration.
Orodruin said:
Note that capitalization is important here, it should be Killing vector after German mathematician Wilhelm Killing. It has nothing to do with murderous vectors. :oldeyes:
But I am sure Wilhelm was quite the killer... :oldbiggrin:
  • Haha
Ahh so ##G_{ab}(q^a)## changes to ##\Big(\partial_a G_{bc}v^a + G_{ba}\partial_c v^a + G_{ca}\partial_b v^a\Big)## due to the transformation!
Thus we get:
$$L = G_{ab}(q) \dot{\vec q^a}\dot{\vec q^b} =\Big(\partial_a G_{bc}v^a + G_{ba}\partial_c v^a + G_{ca}\partial_b v^a\Big) \Big( \dot{\vec q}^a + \lambda \dot{\vec k} + \mathcal O(\lambda^2)\Big) \Big( \dot{\vec q^b} + \lambda \dot{\vec k} + \mathcal O(\lambda^2)\Big) = v^a G_{cb} \dot{\vec q^c}\dot{\vec q^b} + \mathcal O(\lambda^2)$$
Then:
$$L \to v^a L + \mathcal O(\lambda^2)$$
So key is that the vector ##v^a## shows up due to the transformation! Then the conserved quantity stated by Noether's theorem ##p_a k^a## has to be multiplied by ##v^a##.
Then we end up with:
What I do not understand now is how to get ##v^a## out of ##\partial_a G_{bc}v^a + G_{ba}\partial_c v^a + G_{ca}\partial_b v^a##
I obviously got the right answer because I already knew it beforehand.
JD_PM said:
Ahh so Gab(qa)Gab(qa)G_{ab}(q^a) changes to (∂aGbcva+Gba∂cva+Gca∂bva)(∂aGbcva+Gba∂cva+Gca∂bva)\Big(\partial_a G_{bc}v^a + G_{ba}\partial_c v^a + G_{ca}\partial_b v^a\Big) due to the transformation!
No, it does not. Be careful in comparing the Lagrangians before and after transformation. In particular when v^a are not constant.
So may you please explain me what does ##G_{ab}(q^a)## become after the transformation?
I know that after the transformation we end up with the Lagrangian ##L = v^a G_{cb} \dot{\vec q^c}\dot{\vec q^b}##, but I do not know how to deal with the transformation of the matrix ##G_{cb}##.
Please consider I've never dealt with this kind of problem.
JD_PM said:
So may you please explain me what does Gab(qa)Gab(qa)G_{ab}(q^a) become after the transformation?
It becomes ##G_{ab}(q+\epsilon v)## for small ##\epsilon##. Series expand this in ##\epsilon##.
If we expand as a power series in ##\epsilon## we get
$$G_{ab}(q+\epsilon v) = G_{ab}(q+\epsilon v + \epsilon^2 v + ...)$$
But why to do so?
NOTE: I will be online the following hours.
JD_PM said:
If we expand as a power series in ϵϵ\epsilon we get
Gab(q+ϵv)=Gab(q+ϵv+ϵ2v+...)​
No, we do not. What is the series expansion of ##f(x+\epsilon)##?
I am going to bed, it is 23:40 here.
Orodruin I am enjoying so much this discussion, but I'd like to postpone it if you do not mind. I have more questions I'd like to ask in the forum the following days, that is why.
At this point I know the following:
According to Noether's theorem, the corresponding conserved Noether's charge ##Q## is equal to the momentum times the generator of the symmetry, which in this case is ##v^a##
We still have to prove it.
Thank you for this insight so far.
Orodruin said:
it is 23:40 here.
Also here but I am afraid I am becoming PFaholic...
Back at it! :)
To recap: I was trying to understand what does ##G_{ab} (q)## become after the transformation. Next, I had to series expand it.
OK
$$G_{ab}(q+\epsilon v) = G_{ab}(q) + G'_{ab}(q) \epsilon v + G''_{ab}(q) \frac{ (\epsilon v)^2}{2!} + ... $$
So ##G_{ab}(q+\epsilon v) = G_{ab}(q)## because we drop the following terms.
OK so let me correct post #48. I will rewrite it carefully.
Ahh so ##G_{ab}(q)## changes to ##G_{ab}(q + \epsilon v)##.
Then we get (let me avoid typing vector arrows this time)
##L = G_{ab} (q) \dot q^a \dot q^b = \Big( G_{ab}(q + \epsilon v) \Big) \Big( \dot q^a + \lambda \dot k + O( \lambda^2 ) \Big) \Big( \dot q^b + \lambda \dot k + O( \lambda^2 ) \Big) = v^a G_{cb} \dot q^c \dot q^b + O(\lambda^2)##
Do you agree at this point?
JD_PM said:
Back at it! :)
OK
No, you cannot drop the order ##\epsilon## terms. They are crucial and completely necessary for you to compute the derivative. (However, you may ignore terms of order ##\epsilon^2## or higher.) Also, ##q## is generally a set of coordinates and comes with an index and ##G## is not a function of one variable only so you really cannot write ##G'##.
Ahh so I better write
$$G_{ab} (q^c + \epsilon v^a) = G_{ab} (q^c) + \partial_c G_{ab} (q^c) \epsilon v^a + \partial^2_c G_{ab} (q^c) \frac{ (\epsilon v^a)^2 }{2!} + ...$$
I would leave out the indices from the argument, they are just confusing you (better not write the argument at all when the argument is just q actually). Also note that the indices in your argument on the LHS do not match.
OK so we have
$$G_{ab} (q + \epsilon v) = G_{ab} + \partial_c G_{ab} \epsilon v^a + \partial^2_c G_{ab} \frac{ (\epsilon v^a)^2 }{2!} + ...$$
