Using PMOS switch and comparator for 3V 2A overcurrent protection with latch
  • Thread starter Thread starter gnurf
    Protection
2 replies · 2K views
gnurf
I need to prevent a malfunctioning load from drawing too much current from a supply of around 3Vdc@2A(max). There is already a current sensor in series with the load which outputs a voltage, Vsense, proportional to the current drawn by the load.
I was thinking a PMOS switch with the gate tied to the output of a comparator that compares Vsense to a Vref, where Vref would represent the maximum allowed current draw for that load. When a over-current is detected the switch must shut down the load immediately and stay in that state until externally reset (by a microcontroller) or if the load resumes normal operation.
Some kind of hysteresis (or a flip-flop??) -- or something -- is missing from this picture, and I have a feeling there exists some standard way of doing this that I'm unaware of, so any ideas are welcomed. Thanks.EDIT1: Oh, and btw -- high efficiency is a priority.
EDIT2: I've already found what I need (e.g., MAX869), but if you know of a circuit with discrete components that does the same job, I'm still interested for educational purposes.
How about a circuit breaker or fuse?
CS
A circuit breaker or fuse as suggested are the simplest ways to go.
If you're looking to go fancy you can try something similar to a crowbar circuit.
