Using suvat to find time traveled by a cannonball
  • Thread starter Thread starter Camden
    Suvat Time
The discussion revolves around a physics problem involving the motion of a cannonball fired from a castle towards a ship. The problem includes determining the time taken for the cannonball to travel a horizontal distance of 150 meters while falling from a height of 67 meters. Participants reference the use of SUVAT equations and trigonometry in their attempts to solve the problem.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the known variables such as initial velocity, acceleration, and distance, and question how to relate these to find the time of flight. There is an exploration of which SUVAT equation might be applicable to the situation. Some participants express uncertainty about how to derive the time from the given information.
The discussion is ongoing with participants sharing their thoughts on the relevant SUVAT equations. Some guidance has been offered regarding the relationships between the variables involved, but there is no explicit consensus on the approach to take. Participants continue to seek clarification on how to proceed with the calculations.
Participants note that the time value of 3.7 seconds is provided but require proof of this value through calculations. There is mention of constraints such as the lack of a comprehensive list of SUVAT formulas available to some participants.
Camden
In a Castle a cannon is in place to fire at ships.
One ship was hit by a cannonball at a horizontal distance of 150 metres from the cannon.
The height from the cannon above the castle was 67 metres
I need to show the time that was taken from the cannonball to hit the ship.
My attempt is in the attached photo
The answer is 3.7s but I’m not sure how to get to the answer.
Suvat equations
Trigonometry equations
Everything is in the photo
Camden said:
Homework Statement:: In a Castle a cannon is in place to fire at ships.
Relevant Equations:: Suvat equations
You have a little section of the photo with:
photo said:
Vertically
s = 67 m
u = 0 m/s
v =
a = 9.8 m/s2
t = 3.7 s
How did you obtain that t value?
The t value was given to me
I had to prove that t was 3.7s
That little section has the letters S U V A T in that order. Can you find a SUVAT equation that relates the values you know to the one you want to know? (The one you want to know is t).
Yes I am trying to find the t equation but I need to find distance over speed and I know the difference just what I’m stuck on is the speed
You have initial velocity, acceleration and distance travelled. You want to determine time. Surely there is an equation relating those four quantities.
And no, you do not need to find distance divided by speed.
Yes I need to find time but I also need to find final velocity. I don’t know which formula to use
Well, I do not have a list of SUVAT formulas in a textbook because it has been some 40 years since I had a physics textbook. But Google is my friend. I bet I can find a complete list of SUVAT formulas pretty quickly.
Let's Google "suvat equations" and see what we get.
Wikipedia has an article -- "equations of motion". Wiki is pretty good, though with a tendency to get long winded and overly technical on occasion. We'd be better served by simplicity here. But let's give that article a try.
Here we go. They have a relevant section.
https://en.wikipedia.org/wiki/Equations_of_motion#Uniform_acceleration said:
In elementary physics the same formulae are frequently written in different notation as:
##v=u + at##
##s = ut + \frac{1}{2}at^2##
##s = \frac{1}{2}(u + v)t##
##v^2 = u^2 + 2as##
##s = vt - \frac{1}{2}at^2##
[Re-rendered by hand -- I tried and failed to re-tag the LaTeX code in the original]
One of those equations relates the three quantities that you know with the one that you want to confirm.
[Five equations... Of course there are five. There are five variables - S, U, V, A and T. Each of the five equations leaves one of the variables out and relates the other four. I'd never bothered thinking about that until today. If you solved each equation in turn for each of its four variables, that would give you a list totaling twenty equations. I guess that would be useful for the algebra-challenged, but personally I hate memorization worse than algebra. As it turns out, a pre-cooked solution to a quadratic would be a lot messier than the special case we are faced with here, so algebra is our friend]
Once you get time, you can use it to determine final velocity.
Thankyou!
  • · Replies 44 ·
  • · Replies 16 ·
  • · Replies 98 ·
