Changing V(x) to V(t): Chain Rule Application?
The discussion focuses on converting the velocity function V(x) = a*x² + b*x + c, defined in terms of position x, to a function of time t using the chain rule. The key steps involve recognizing that velocity V is defined as dx/dt, leading to the equation dt = dx/(a*x² + b*x + c). By integrating both sides, one can express time as a function of position, subsequently allowing for the derivation of position as a function of time. The integration process is crucial for successfully transitioning from V(x) to V(t).
  • Understanding of calculus, specifically integration and differentiation.
  • Familiarity with the chain rule in calculus.
  • Knowledge of functions and their transformations.
  • Basic concepts of motion, including velocity and position relationships.
  • Study the application of the chain rule in calculus with practical examples.
  • Learn about integration techniques for solving differential equations.
  • Explore the concept of antiderivatives and their applications in physics.
  • Investigate the relationship between velocity, acceleration, and time in motion equations.
Students and professionals in physics, mathematics, and engineering who are working with motion equations and require a solid understanding of calculus principles for transforming functions.
StephenSF8
I have a function for velocity, V in terms of position, x. The equation is of the form V(x) = a*x2+b*x+c. Initial conditions are x=0, t=0.
How do I change from V(x) to V(t)? It seems this would be an application of the chain rule, dy/dx = dy/du * du/dx, but I'm struggling to adapt it to this situation. Am I way off base?
Thanks!
Assuming t means time, then V=dx/dt. So dt = dx/(a*x2+b*x+c). Integrate both sides to get t as a function of x. Solve for x as a function of t. Then take the derivative to get V. Good luck!
Velocity is the result of differentiating a position equation. To reverse that you have two options, (the same pretty much): Integrate or find the Antiderivative.
Enjoy.
You assume correct.
This is what I was missing. I was able to perform the integration and solve for x and all is well. Thanks for the help!
  • · Replies 22 ·
