Validity of identical eigenfunction of commutating operators
  • Level: Undergrad
  • Thread starter Thread starter hokhani
12 replies · 2K views · last reply
hokhani
TL;DR
An example of a function which is eigenstate of ##\hat {\mathbf L_z}## but not ##\hat {\mathbf L^2}##
I got confused about an elementary statement in quantum mechanics: As far as I know, the two commuting operators like ##\hat {\mathbf L_z}## and ##\hat {\mathbf L^2}## always have identical eigenfunctions. But, if we consider every function in the form ##\psi=f(r,\theta) e^{im\phi}## where ##f(r,\theta)## is any function including the normalization coefficient, then, this function is always eigenfunction of ##\hat {\mathbf L_z}## (##\hat {\mathbf L_z} \psi=m\hbar \psi## ) but it is not always the eigenfunction of ##\hat {\mathbf L^2}##. What’s wrong with my thinking here?
If two operators commute, then at least some of the eigenfunctions of one will be eigenfunctions of the other - but not necessarily all. It kind of has to be that way; otherwise any eigenfunction of ##L^2## would be an eigenfunction of both ##L_x## and ##L_y## because both commute with ##L_2##.
Consider$$A=\begin{pmatrix}1&0\\0&2\end{pmatrix}$$and the identity ##2\times2## matrix ##I##. Surely$$v=\begin{pmatrix}1\\1\end{pmatrix}$$is an eigenvector of ##I##.
Thanks, but by operators I meant Hermitian operators.
All Hermitian operators commute with ##I##. And every vector is an eigenvector of ##I##.
This is wrong. There must be a common eigenbasis. But, one operator might have two (or more) eigenvectors corresponding to the same eigenvalue. This is called degeneracy. In this case, the operator will have a mutli-dimensional eigenspace corresponding to that eigenvalue Whereas, if the other operator does not have this degeneracy, then it has two separate one-dimensional eigenspaces, corresponding to the different eigenvalues.
So which one is not Hermitian in my example, ##I## or ##A## ?
Edit: for 2 commuting observables there is a basis in which they are both diagonal. Instead of looking at the infinite-dimensional representation, it is easier to consider a ##2\times2## restriction that demonstrates the same basic idea.
Thanks, but let's write the commutation in the nondegenerate basis of ##\hat {\mathbf L_z}##, i.e., ##|m\rangle##. We have: $$\langle m| [\hat {\mathbf L_z}, \hat {\mathbf L^2}]|m' \rangle =0 \rightarrow (m'-m)\hbar \langle m| \hat {\mathbf L^2}|m' \rangle=0.$$ which means that ##\hat {\mathbf L^2}## is diagonal in the basis##|m\rangle##. What is wrong with this statement?
Nothing. All eigenvectors of ##L_z## are eigenvectors of ##L^2##. But there are eigenvectors of ##L^2## that are not eigenvectors of ##L_z##.
Sorry, you are right.
However, in the post #1, I sent the function ##\psi=f(r,\theta) e^{im\phi}## which is always the eigenfunction of ##\hat{\mathbf{L_z}}## but not always the eigenfunction of ##\hat{\mathbf{L^2}}##.
Hints don't seem to work, so I'll say it explicitly: superpositions of the common diagonalizing basis vectors may still be eigenfunctions of one observable, but not necessarily of the other.
Could you please see the post #7? It approves more the discrepancy said in the post #1.
As @PeroK replied in #8, nothing is wrong with #7. Only basis states are considered there. But your ##\psi## in OP (#1) is a superposition in general.
Edit: the error in #7 is claiming that ##\mathbf{\hat L}_z ## is nondegenerate. There are infinitely many states in the ##|l,m\rangle## basis for which ##m=1## .
##|1,1\rangle## and ##|2,1\rangle## are eigenstates of both operators. However, ##|1,1\rangle+|2,1\rangle## is an eigenstate of ##\mathbf{\hat L}_z ## but not of ##\mathbf{\hat L}^2 ## (if you'll think about it, it is my example in #3).
