Vanadium Content in 4330V Steel
  • Thread starter Thread starter Lazorbeam
    Steel
The discussion focuses on the Vanadium content in 4330V steel, which ranges from 0.05% to 0.15%. Participants highlight that Vanadium acts as a carbide and nitride former, enhancing the steel's strength through dispersion-strengthening and influencing grain structure. Suppliers generally recommend a nominal Vanadium content of approximately 0.07%, with considerations for synergistic effects with chromium (Cr) and molybdenum (Mo). The impact of heat treatment and working processes on microstructure is also emphasized as crucial for performance.
  • Understanding of alloy steel properties, specifically 4330V steel
  • Knowledge of Vanadium's role in metallurgy
  • Familiarity with heat treatment processes
  • Basic concepts of tensile strength and hardness testing
  • Research the effects of Vanadium on steel properties through academic papers
  • Learn about heat treatment techniques for 4330V steel
  • Investigate the synergistic effects of chromium and molybdenum in alloy steels
  • Conduct comparative testing on samples with varying Vanadium content
Metallurgists, materials engineers, and professionals in the mining industry seeking to optimize the performance of 4330V steel in tool manufacturing.
Lazorbeam
Hi all,
Hope I'm posting this in the right forum! I have some questions with regards to 4330V steel. This is a Vanadium-modified 4330 steel, with Vanadium contents ranging from 0.05 - 0.15%.
I work for a company that builds tools for the mining industry, and our steel suppliers are divided on the issue of Vanadium content. Some say it should be near the 0.05% minimum, others say it should be at or near 0.15%.
The problem is that nobody here understands the impact of Vanadium in this steel and how (if at all) it affects its properties.
Any input?
Lazorbeam said:
Hi all,
Any input?
Vanadium is a carbide and nitride former, so it strengthens steels by dispersion-strengthening. It also affects grain structure.
It seems that a number of suppliers prefer a nominal content of about 0.07 or mid range of 0.05 to 0.10%. There could be synergistic effects with Cr and Mo contents.
http://www.westyorkssteel.com/alloy-steel/oil-and-gas/aisi-4330v/
http://www.westyorkssteel.com/files/aisi-4330v.pdf
http://customer.cartech.com/assets/documents/datasheets/4330+V.pdf
http://www.encoremetals.com/docs/product_manual/Section%202.0%20Alloy%20Steels.pdf
It is also important to consider the heat treatment and hot/cold working which will affect the microstructure.
Effects of V on steels:
http://vanitec.org/wp-content/uploads/2011/09/Vanadium-in-Medium-and-High-Carbon-Steels.pdf
http://www.hsla-v.org/assets/documents/Effect_of_Vanadium.pdf
http://www.kau.se/sites/default/files/Dokument/subpage/2010/02/21_269_287_pdf_18759.pdf
https://online.tugraz.at/tug_online/voe_main2.getvolltext?pCurrPk=32837
http://www.archivesmse.org/vol33_2/3321.pdf
http://steel.keytometals.com/Articles/Art182.htm
http://steel.keytometals.com/Articles/Art85.htm
It's best to look at different sources.
One might try to obtain some samples with one on the low end of the V range and one on the high end and compare tensile strength, hardness, and impact strength.
  • · Replies 22 ·
  • · Replies 18 ·
10K
