How to Calculate Variable Force on a Particle with Varying Coordinates?
To calculate the work done by a variable force on a particle, integration is necessary due to the changing nature of the force. The provided formula, W = -k(y i + x j)d, applies only to constant forces, which is not suitable in this case. Accurate coordinates of the particle are essential for determining the correct value of d. The discussion emphasizes the importance of integrating the force over the path to obtain the work done. Understanding these concepts is crucial for solving problems involving variable forces.
rudransh verma
A force ##\vec F=-k(y\hat i+ x\hat j)## where k is constant acts on the particle moving in x-y plane from origin, the particle is taken along the positive x axis to the point (a,0) and parallel to y axis to a point (a,a). The total W by the Force on the particle is
W=F.d
##W=-k(y\hat i+ x\hat j)d##. I am not getting the coordinate of particle correctly so that I can find the value of d. Also the force is varying.
Since the force is varying, you'll need to integrate. The formula you gave is for constant force. And the coordinates are given.
Oh yes! Thanks.
  • · Replies 16 ·
  • · Replies 25 ·
