Variable Resistror, Calculating Vo
  • Thread starter Thread starter Jreyes613
    Variable
13 replies · 5K views
Jreyes613
A variable resistor, R, is connected to the terminals of a battery (dashed box in the diagram). The graph below shows data collected in the circuit as R is varied. What is V0, in volts?
What is the internal resistance, r, in ohms?
Ohm's Law
I know that for this case, Vo will be found where the current is calculated to be at its lowest.
from the graph that i am given, It is not clear where it will equal zero, as for the internal resistance, i know that I=ε/r
so
-r=dV/dI
the slope of a V vs I graph will give the internal resistance.
Do you have a circuit diagram that you can post? Your graph shows current versus resistance; is the resistance that of the variable resistor? How were they measured or determined?
oops! i forgot to click attach on the second file.
new here :)
new here :)
No problem :smile: I see a voltmeter in the circuit, but no current meter. How were the values for the current versus resistance plot obtained?
these were given to me! this is all the information given.
Okay, fair enough. In that case, I'd suggest that the first thing to do would be to write an expression for the current in the circuit assuming that the cell has voltage Vo, with resistors R and r as shown.
okay, so i have the equation I=V/R
since the resistors are in parallel,
(1/Req)=(1/R+1/r)
take the inverse of both sides to get Req
so i get
I=Req(Vo)
Is this right?
(1/Req)=(1/R+1/r)
so i get
I=Req(Vo)
Is this right?
The resistors are not in parallel; the battery cell is between two of their leads so they are not connected to each other at both ends.
okay, so it would still be
I=Req(Vo)
but instead i would just add the resistances without inversing them.
Req= R+r
right?
I=Req(Vo)
Hmm. Not quite. Ohm's law: V = I*R, so that I = V/R.
Req= R+r
right?
Sure. But write the equation without replacing R and r with Req; you want to have "access" to those variables as you proceed.
okay yes, ( i saw my bad re arranging in the equation)
So I will end up with
I=Vo/(R+r)
I am still in the mist here... i am not sure how to calculate each individual resistor since i am not given their individual values.
I=Vo/(R+r)
Ha! :smile: That's where the graph comes in. You can read off convenient pairs for R and I and build yourself a couple of equations using the expression above as a template. Two unknowns require two equations.
thank z, me and my friend used I=Vo/(R+r) to solve for Vo,
Vo=I(R+r)
got two equations
Vo=5.25(r) *since when R=0, I=5.25
Then i used another point
Vo=1.5(2.5+r)
and solved for Vo.
With this, i was able to solve for my internal resistance to equal one.
:) thank you gneill!
Vo=I(R+r)
got two equations
Vo=1.5(2.5+r)
and solved for Vo.
Glad to help! :smile:
