Various forces on various objects
  • Thread starter Thread starter Just_enough
    Forces
33 replies · 4K views
Just_enough
sorry, me again.
The following figures show various forces acting on gliders of various masses at rest on a frictionless track. In each case, the force is applied for 30cm. The choice listing the examples in decreasing order for the increase in kinetic energy is {-4J < -2J < 1J}
answer:(a) C > A=B > D (b) B=C > D > A (c) C > A > B > D (d) B > C > D > A (e) B > C > A > D
W=FD
F= MA
I don't clearly understand the questions here, is it asking for sorting it from most work to least? (cant ask teacher since he nevers check his email). if so wouldn't it be D>c>b>a since the mass of it all is combine on d, so it requires more force? I don't understand how in the answer, a block can be = to another block, of the other block (combined) mass is more?
What determines the change in kinetic energy?
Yes. It's asking you to put them in order of the KE gained. So which one gains the most KE? By conservation of energy the KE gained = work done by the applied force.
if so wouldn't it be D>c>b>a since the mass of it all is combine on d...
No. Treat all of the drawings as separate experiments. They don't collide.
One can equal another if it gains the same KE as another.
mass and velocity, but how can I find velocity without the time? I'm looking at all the velocity equations I know and it all depend on time.
Forget all that. Think of the work-energy theorem.
When I say "forget all that" I am being a bit facetious. You could do it that way, but that's way harder than necessary. You are given the force applied and the distance -- so use it.
Ok, so I calculated out the work done on each block separately, A = 500J B=2000J C=1000J D= 1125J, so it's B>D>C>A, but that's not a choice, the closest is B=c>d>a and the reason why b=c is because c is half the weight as b, and if it was the same it would ACTUALLY be equal? am I correct?
edit: wait... why am I multiply force by the mass? ignore this then...
Hint: The distance is the same for each, so just arrange by force.
oh wow... that's so much easier
As Doc Al writes, you do not need to find the velocity. But if you insist on taking that route...
There are five standard variables in the equations for constant acceleration, the symbols for them spelling the acronym SUVAT.
Any four can be related by an equation, so there are five standard equations, each omitting one variable. In particular, one omits t. That one is effectively an energy equation, but with mass canceled out.
what if say that it's being pushed for 1s? can we ignore 1s too since it's all being pushed for 1 s?
Nope. Since each will have a different acceleration, the distances will be different even though the time is the same. But in that case, you might want to use the impulse momentum theorem to help find the change in energy. (It will take a few steps.)
So I would have to find accel from the force, from there find the velocity of 1s, then from there find the impulse and sort the impulse in increasing order?
if so my increasing order should be B=C>D>A does that sound right?
Correct.
The easy way is to use KE=work=force*displacement.
The hard way would be to use Newton's law and the equations of motion (SUVAT) to calculate the final velocity for each. Then use KE=0.5mv2
CWatters said:
Correct.
if I were to use force*displaycement, what would happen to the time then? where would that go?
I'm confuse, still on the same model as original post, it's ask for " increasing order for the increase in momentum is" but it's giving me
(a) C < B < D < A (b) C < A=B < D (c) B=C < D < A (d) C < B=D < A (e) A < C < D < B and the closest to my answer is C, but the signs are wrong... I think.
Are the sign correct?
One of those answers is correct, but it is not C.
I've put the thread back to Unsolved.
it's not? I thought it was list the impulse in increasing order
Sure, but you first have to calculate the impulses. I see no working by you in that regard.
I did not understand this part of an earlier post:
Where do you get 1s from? In each case, the force is applied over the same distance. That distance will be covered in different times. So you cannot multiply the force by 1s to get the impulse.
from
Just_enough said:
So I would have to find accel from the force, from there find the velocity of [.1s (my bad)], then from there find the impulse and sort the impulse in increasing order?
and I did the work on paper. I didnt multiply it by the seconds, I first found the accel by diving the force by mass, then from there use A=Δv/Δt for the interval of .1s to get velocity final, and from there I did mass time Δv (v final since initial is 0) which gave me the [change in momentum]
Using an arbitrary 0.1s is no more correct than using an arbitrary 1s.
The change in momentum is over whatever period the force is applied for. The greater the acceleration, the sooner the 30cm is covered, so the shorter the time.
sorry, what? I don't understand what you mean
Explain how you justify multiplying the acceleration by 0.1s. Where does the 0.1 s come from?
Oh, sorry, I was suppose to post the whole question, "If instead, the forces in the above figures are applied for 0.1s, the choice listing theexamples in increasing order for the increase in momentum is"
That is generally a good idea.
Just_enough said:
"If instead, the forces in the above figures are applied for 0.1s, the choice listing the examples in increasing order for the increase in momentum is"
That makes a different one of the offered answers correct.
The method you described in post #20 is not the simplest, but it should have worked. Please post detailed working for at least one of the four arrangements.
uh, do you mean show my work? if so, I just did like I say, find the accel of each the blocks, so for box a it's 50 = 10a then divide both side by 10 and go a= 5 (same for block b and D) and for block c I did 100/10 since the force was 100 and mass is 10 and got a=10.
from there, since block a,b, and d have accel of 5, I only need to find vf once, so I did 5=vf-vi/tf-ti, and vi and ti is 0, and what I got is 5=vf/.1s,
then times 5 by .1 to cancel out the denominator (and did this for acceleration of 10 for block c). after that, I multiply .5m/s to mass of blocks that have accel of 5 to get my momentum and multiply 1 by 10 for block c(A =5, B= 10, C =10, D = 7.5)
Which matches one of the choices, no?
The only choice on there with B=C is C, but you said it was in correct...
Are we looking at the same list?
no, you're looking at the original list instead of the new list I posted #16. (a) C < B < D < A (b) C < A=B < D (c) B=C < D < A (d) C < B=D < A (e) A < C < D < B
