Vector addition problem - component method
15 replies · 13K views
Larrytsai
Vplane = 63km/hr at x degrees and direction
Vwind = 47km/hr at 211 degrees
Vg = unknown speed at 165 degrees
find the unknowns
my attempt using component method:
(Cos 165)Vg = (Cos 211)47 + (Cos theta)63
(Sin 165)Vg = (Sin 211)47 + (Sin theta)63
from here i think I am supposed to isolate Vg and then subsitute to find the unknown angle and then plug the angle into get the speed but I am not quite sure
I know i can use the cosine law or sine law but I have to learn both ways so that's why I am using the component method
find the unknowns
I think the easiest way for you to solve this system of equations is to isolate [tex]cos(\theta)[/tex] in the first equation, [tex]sin(\theta)[/tex] in the second one, and then square both equations, add them together and take advantage of the fact that [tex]sin^2(\theta)+cos^2(\theta)=1[/tex] to sollve for [tex]V_g[/tex]. After that, plug your solution into either equation and solve for [tex]\theta[/tex]. If you post your solution, I'll be happy to check it.
hmmm, that's where i ran into trouble, isolating theta i don't understand how to isolate theta. like do i use Sin-1? and how would it look?
Start with the first equation:
[tex]V_gcos(165^{\circ}) = 47cos(211^{\circ}) + 63cos(\theta)[/tex]
Can you solve this for [tex]cos(\theta)[/tex]?
ohhh okay so now i got (Vg(Cos 165) - 47(Cos 211))/63 = Cos (theta)
i think that's right
Yup, so what is [tex]cos^2(\theta)[/tex] then?
by Cos^2 u mean Cos-1 right? and if so i don't see what will happen to my other unknown
Nope, I mean [tex](cos(\theta))^2[/tex]...it will become clear why I want you to find this in a minute.
oo I am just lost now sorrry =(
If
[tex]cos(\theta)=\frac{V_gcos(165^{\circ})-47cos(211^{\circ})}{63}[/tex]
then
[tex]cos^2(\theta)=\frac{[V_gcos(165^{\circ})-47cos(211^{\circ})]^2}{63^2}[/tex]
...Now, solve the second equation for [tex]sin(\theta)[/tex] and then find [tex]sin^2(\theta)[/tex]
okay so i got
Sin^2(theta) = ((Vg(Sin165)-47(Sin211))^2)/(63)^2
well now I am wondering does that Cos^2 and Sin^2 isolate theta?
Larrytsai said:
okay so i got
Okay, so now you have:
and
[tex]sin^2(\theta)=\frac{[V_gsin(165^{\circ})-47sin(211^{\circ})]^2}{63^2}[/tex]
so what is [tex]sin^2(\theta)+cos^2(\theta)[/tex]?
from what u said earlier it = 1
Yes, there is a trigonometric identity: http://en.wikipedia.org/wiki/Pythagorean_trigonometric_identity" that it will equal 1 for any theta.
so you get:
[tex]sin^2(\theta)+cos^2(\theta)=\frac{[V_gsin(165^{\circ})-47sin(211^{\circ})]^2}{63^2} + \frac{[V_gcos(165^{\circ})-47cos(211^{\circ})]^2}{63^2}=1[/tex]
And so,
[tex]\frac{[V_gsin(165^{\circ})-47sin(211^{\circ})]^2}{63^2} + \frac{[V_gcos(165^{\circ})-47cos(211^{\circ})]^2}{63^2}=1[/tex]
Now, can you expand this equation to find a quadratic equation for [tex]V_g[/tex]?
okay so i tried to find wat Vg is equal to and i get 2.11 which seems wrong to me
my work is shown here
1=((Vg(cos165)+40.287)^2 + (Vg(Sin165)+24.207)^2)/(3969)
multiply both sides by 3969
3969=(Vg(Cos165)+40.287)^2 + (Vg(Sin165)+24.207)^2
square root both sides
63=-0.7071Vg+64.494
subtract 64 to both sides
-1.494= -0.7071Vg
0.7072 came from cos165+sin165
Vg = -1.494/-0.7071
Vg= 2.11
you can't just take the square root of the right hand side here, because it is a sum of 2 squares not just a perfect square...you have to expand each term first like this:
[tex]\Rightarrow [V_gsin(165^{\circ})-47sin(211^{\circ})]^2 +[V_gcos(165^{\circ})-47cos(211^{\circ})]^2=63^2[/tex]
[tex]\Rightarrow [V_g^2sin^2(165^{\circ})-94V_gsin(165^{\circ})sin(211^{\circ})+47^2sin^2(211^{\circ})] +[V_g^2cos^2(165^{\circ})-94V_gcos(165^{\circ})cos(211^{\circ})+47^2cos^2(211^{\circ})]=63^2[/tex]
[tex]\Rightarrow [sin^2(165^{\circ})+cos^2(165^{\circ})]V_g^2-94V_g[sin(165^{\circ})sin(211^{\circ})+cos(165^{\circ})cos(211^{\circ})]+47^2[sin^2(211^{\circ})] +cos^2(211^{\circ})]=63^2[/tex]
Now, there are two useful Trig Identities: (1) [tex]sin^2(x)+cos^2(x)=1[/tex] and (2) [tex]sin(x)sin(y)+cos(x)cos(y)=cos(y-x)[/tex].
Using these you get:
[tex](1)V_g^2-94cos(211^{\circ}-165^{\circ})V_g+(1)47^2=63^2[/tex]
[tex]\Rightarrow V_g^2-94cos(46^{\circ})V_g+(47^2-63^2)=0[/tex]
Now, can you solve for [tex]V_g[/tex]?
You should get 2 solutions!
