MHB Is the Calculated Osculating Plane and Binormal Correct for $\theta=0$?
  • Thread starter Thread starter WMDhamnekar
    Assistance
The discussion centers on verifying the correctness of the calculated osculating plane and binormal at $\theta=0$. The initial claim states the osculating plane equation as $-\sqrt{\frac{1}{6}}x + \sqrt{\frac{2}{3}}z - \sqrt{\frac{1}{6}}=0$ and the binormal as $\hat{B}(\theta=0)=\left[-\sqrt{\frac{1}{6}},-\sqrt{\frac{1}{6}},\sqrt{\frac{2}{3}}\right]$. Another participant provides an alternative calculation for the osculating plane and binormal, concluding that at $\theta=0$, the plane is 0 and the binormal is $\left[0,\frac{2}{\sqrt{5}},-\frac{1}{\sqrt{5}}\right]$. The conversation highlights discrepancies in the calculations and seeks confirmation on the correct values. The discussion emphasizes the importance of accurate mathematical derivations in determining the osculating plane and binormal.
WMDhamnekar
MHB
I am working on this question. Any math help, hint or even correct answer will be accepted.
Hi,
Answer to question (a): The equation of the osculating plane at $\theta=0$ is $-\sqrt{\frac16}x + \sqrt{\frac23}z -\sqrt{\frac16}=0$ and binormal $\hat{B}(\theta=0)=\left[-\sqrt{\frac16},-\sqrt{\frac16},\sqrt{\frac23}\right]$
Is this answer correct? In my opinion, it should be correct.
Answer (b):$\vec{r}(\theta)=\left[2\cosh{\frac{\theta}{2}}, 2\sinh{\frac{\theta}{2}},2\theta\right] \implies \vec{r'}(\theta)=\left[\sinh{\frac{\theta}{2}}, \cosh{\frac{\theta}{2}},2\right],||\vec{r'}(\theta)||=\sqrt{\sinh^2{\frac{\theta}{2}}+\cosh^2{\frac{\theta}{2}}+4}$
$||\vec{r'}(\theta)||_{(\theta=0)}=\sqrt{[0,1,4]}=\sqrt{5}, \hat{T}(\theta)=\left[\frac{\sinh{\frac{\theta}{2}}}{\sqrt{\sinh^2{\frac{\theta}{2}}+\cosh^2{\frac{\theta}{2}}+4}}, \frac{\cosh{\frac{\theta}{2}}}{\sqrt{\sinh^2{\frac{\theta}{2}}+\cosh^2{\frac{\theta}{2}}+4}},\frac{2}{ \sqrt{\sinh^2{\frac{\theta}{2}}+\cosh^2{\frac{\theta}{2}}+4}} \right],\hat{T}(\theta)_{(\theta=0)}=[0,\frac{1}{\sqrt{5}},\frac{2}{\sqrt{5}}]$
Equation of the osculating plane at $\theta=0$ is 0 and binormal to the curve at point (2,0,0) is $\left[0,\frac{2}{\sqrt{5}},-\frac{1}{\sqrt{5}}\right]$
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
