Vector drive - faster than light?
9 replies · 3K views · last reply
android34
If a spaceship is traveling at 90% the speed of light on the X axis. And it is also traveling 90% the speed of light on the Y axis. What is its velocity?
1.27c. But your supposition doesn't describe the behavior of a physical spaceship.
The solution to the apparent paradox is to model how it could get to those speeds. The ultimate answer is: it couldn't.
The reason is that speeds near C are not summed. They are the result of the formula 1/(v1 = 1-(v0^2/c^2)^.5).
Morgan (l982) estimated that the exhaust velocity of a pion- relecting matter/antimatter rocket could be in excess of 0.9c. If the spaceship is a sphere, and one antimatter rocket is aimed in the X axis, and one antimatter at 90 degrees to X 1/4 the way across the sphere is aimed in the Y axis, and both push to 0.9c, is what you say still true?
android34 said:
Morgan (l982) estimated that ...
You need a better and more complete reference than that!
Zz.
http://www.aiaa.org/Participate/Uploads/2003-4676.pdf
Burried in there is 0.9c
Hi android34, welcome to PF
This is actually not very difficult to approximate using the http://en.wikipedia.org/wiki/Four-momentum" .
We will start with a rocket with 1.0 kg payload/vehicle and 2.0 kg fuel (3.0 kg total). We will consider the entire payload of fuel to be burnt instantaneously with 100% efficiency at an exhaust velocity of 0.9 (using units where c=1). We will consider two cases, the first where all of the exhaust goes in the -x direction and the second where half goes 45º above the -x axis and half goes 45º below. We will simply use the conservation of four-momentum before and after the burn to determine the speed of the rocket.
Case 1:
3.0 (1,0,0,0) = 1.0 (γ,γv,0,0) + m (2.29,-2.06,0,0)
eliminating m and solving for v
v = 0.78
Case 2:
3.0 (1,0,0,0) = 1.0 (γ,γv,0,0) + m (2.29,-1.46,1.46,0) + m (2.29,-1.46,-1.46,0)
v = 0.71
So you will go faster by sending your exhaust off in the opposite direction you want to go instead of splitting it up on two orthogonal axes.
Propulsion systems do not "push to [a velocity]"; they provide (a force which results in) an acceleration.
If you accelerate for time X to reach v=.9c, and then accelerate for time X again, your final velocity will only be about .99c.
Yes, it is still true.
Zz.
The choice of propulsion is largely academic, so lack of a reference is not a show-stopper. Any propulsion that can (theoretically) accelerate a craft to .9c will do. There are a few well-known ones that are unlikely to be contested.
