Calculating Magnitudes and Ratios of Position Vectors on a Line
  • Thread starter Thread starter pavadrin
    Line Vector
The discussion focuses on calculating the magnitudes and ratios of position vectors A, B, and C on the line defined by r = 2i + 3j + λ(i + 4j) for λ values of -1, 1, and 2. The correct magnitude of vector AB is determined to be the square root of 17, while the magnitude of vector BC is incorrectly calculated as the square root of 20. The ratio AB:BC is clarified to be the comparison of the lengths of these two segments, which is found to be 2 after correctly calculating the magnitudes.
  • Understanding of vector algebra and position vectors
  • Familiarity with calculating magnitudes of vectors
  • Knowledge of ratios and their applications in geometry
  • Ability to substitute values into vector equations
  • Learn how to derive position vectors from parametric equations
  • Study the properties of vector magnitudes and their calculations
  • Explore the concept of ratios in geometry and their significance
  • Practice solving problems involving multiple vectors and their relationships
Students studying vector mathematics, educators teaching geometry, and anyone looking to improve their skills in vector calculations and algebraic manipulation.
pavadrin
Points A, B and C lie on the line r = 2i + 3j + λ(i + 4j) and have position vectors given by λ=-1, λ=1 and λ=2 respectively.
Find a) AB
b) AB:BC
The answer for part a is the square root of 17 (in exact form) however I keep getting the suare root of 20.
Here is what I am doing:
OB = 3i – j and OC = 5i – 5j
BC= BO + OC
BC= -(3i – j) + (5i – 5j)
BC= 2i – 4j
Therefore the magnitude of BC = square root of 20
As for part b, I’m not sure what it’s asking me to do
Thanks
Pavadrin
Find a) AB
b) AB:BC
BC= BO + OC
BC= 2i – 4j
Thanks
Pavadrin
I don't get it. The first part is asking for the magnitude of AB, yet you seem to be working out the magnitude of BC?:confused:
In any case, your position vectors for both OB and OC are wrong. How did you do that? All you have to do is substitute the given values of λ into the equation to get the position vectors.
Maybe I think it'd be better if you showed full working on how you get OA, OB and OC, because the first part is simple algebra.
Part b) AB:BC is simply asking you to find the ratio between the lengths of the two line segments AB and BC. All you have to do is find |AB|, |BC| then take the ratio (I get two).
sorry, it was meant to say the magnitude of BC, not AB. I have solved this now, so there's no need to worry bout it. As for part b), thanks for clearing that piont up, i should be able to work from here, otherwise i will re-post asking fro help
thanks
  • · Replies 63 ·
