Vector field (rotors and nabla operators)
The discussion revolves around solving the equations for the vector field ##\vec{A}##, specifically finding values for ##\alpha## and ##p## such that both the curl and divergence of ##\vec{A}## equal zero. Participants analyze the expressions for ##\nabla \times \vec{A}## and ##\nabla \cdot \vec{A}##, noting potential errors, particularly regarding a missing factor of 3 in the divergence equation. Consensus emerges that ##p=0## and ##\alpha=1/3## are the correct values, although some confusion persists about the calculations and identities used. The final part of the discussion addresses how to express the scalar potential associated with the vector field, leading to a detailed formulation of the potential function ##U##.
skrat
Find ##\alpha ## and ##p## so that ##\nabla \times \vec{A}=0## and ##\nabla \cdot \vec{A}=0##, where in ##\vec{A}=r^{-p}[\vec{n}(\vec{n}\vec{r})-\alpha n^2\vec{r}]## vector ##\vec{n}## is constant.
##\nabla \times \vec{A}=\nabla \times [r^{-p}\vec{n}(\vec{n}\vec{r})-r^{-p}\alpha n^2\vec{r}]=##
##=r^{-p}(\vec{r}\vec{n})\nabla \times \vec{n}+\nabla(r^{-p}(\vec{r}\vec{n}))\times \vec{n}-r^{-p}\alpha n^2\nabla \times \vec{r}-\nabla(r^{-p}\alpha n^2)\times \vec{r}=##
##=0+[(\vec{r}\vec{n})\nabla r^{-p}+\nabla(\vec{r}\vec{n})r^{-p}]\times \vec{n}-0-[r^{-p}\alpha n^2\nabla \times \vec{r}+\alpha n^2\nabla r^{-p}\times \vec{r}]=##
##=(\vec{r}\vec{n})(-p)r^{-p-2}\vec{r}\times \vec{n}##
##\nabla \cdot \vec{A}=\nabla [r^{-p}\vec{n}(\vec{n}\vec{r})-r^{-p}\alpha n^2\vec{r}]=##
##=\nabla (r^{-p}(\vec{n}\vec{r}))\vec{n}-r^{-p}\alpha n^2\nabla \vec{r}-\nabla(r^{-p}\alpha n^2)\vec{r}=##
##=(r^{-p}\vec{n}-pr^{-p-2}(\vec{r}\vec{n})\vec{r})\vec{n}-3\alpha n^2 r^{-p}+p\alpha n^2r^{-p-1}##
I know something is wrong, I just don't know what and where :(
Does this mean that from ##\nabla \times \vec{A}=0## we know that ##p=0## and accordingly from the second equation that ##\alpha =-\frac{1}{3n}## ?
There should be a factor of 3 in the first term and the last term should have ##r^{-p}## instead of ##r^{-p-1}##.
I think you are correct about ##p=0##.
hmmm.
First term only:
##\nabla r^{-p}(\vec{n}\vec{r})\vec{n}=##
##=r^{-p}(\vec{n}\vec{r})\nabla\vec{n}+(\nabla r^{-p}(\vec{n}\vec{r}))\vec{n}=##
##=0+[(\vec{n}\vec{r})\nabla r^{-p}+(\nabla(\vec{n}\vec{r}))r^{-p}]\vec{n}=##
##=[-p(\vec{n}\vec{r})r^{-p-1}\frac{\vec{r}}{r}+r^{-p}\vec{n}]\vec{n}=##
##=-pr^{-p-2}(\vec{n}\vec{r})^2+r^{-p}n##
I don't know where would factor 3 come from?
skrat said:
hmmm.
First term only:
##=-pr^{-p-2}(\vec{n}\vec{r})^2+r^{-p}n^2##
I meant that it should be ##3r^{-p}n^2## instead of ##r^{-p}n^2##. How do you get ##r^{-p}n^2##?
Well
##\nabla(\vec{r}\vec{n})=\vec{n}##
##\vec{n}r^{-p}## and finally ##\vec{n}^2r^{-p}=n^2r^{-p}##
skrat said:
Well
No, this is not correct. How do you conclude this?
##\nabla(\vec{n}\vec{r})=\nabla(xn_x+yn_y+zn_z)=(\frac{\partial }{\partial x}(xn_x),\frac{\partial }{\partial y}(yn_y),\frac{\partial }{\partial z}(zn_z))=(n_x,n_y,n_z)=\vec{n}##
is it not?
is it not?
Weird. I was about to correct you because you seem to consider each term as a vector component, but when I wrote the thing down it resulted in the exact same thing :P
\nabla(\vec{n}.\vec{r})= \nabla(xn_x+yn_y+zn_z)=\left( \frac{\partial }{\partial x}(xn_x+yn_y+zn_z),\frac{\partial }{\partial y}(xn_x+yn_y+zn_z),\frac{\partial }{\partial z}(xn_x+yn_y+zn_z) \right)=(n_x,n_y,n_z)=\vec{n}
I was a bit lazy and didn't write terms that disappear after derivation. :)
is it not?
Hmm...that looks correct although the following identity I found on wiki doesn't seem to agree.
$$\nabla (\vec{f}\cdot \vec{g})=(\vec{f}\cdot \nabla)\vec{g}+(\vec{g}\cdot \nabla)\vec{f}+\vec{f}\times(\nabla \times \vec{g})+\vec{g}\times(\nabla \times \vec{f})$$
In the prsent case, ##\vec{f}=\vec{n}## and ##\vec{g}=\vec{r}##. Three terms in the above identity are zero and ##\nabla\cdot r=3## and this gives the factor of 3. Any idea what's wrong with the above?
http://en.m.wikipedia.org/wiki/Vector_calculus_identities
The first term is the only non-vanishing term. ##\nabla \cdot r \neq r \cdot \nabla##. The first is a scalar (divergence of r) and the latter is a differential operator.
Thanks CAF!
I haven't yet seen that in the book I am currently following. How do you calculate ##\vec{r}\cdot \nabla##? (Sorry if this is an idiotic question, I have only a 2-days experience with vector calculus :-p )
I made this calculation here breaking into components and I got the same result. p=0 and \alpha =1/3. How do you know this is wrong?
edit: excuse my blindness, that's not the result you found.
Mainly because I got ##\alpha =-\frac{1}{3n}## and you haven't.
No other reason actually. I just doubt that I did right.
Nonononononono!
I have a sign error in my notes. You are right, I also get ##\alpha = \frac 1 3 ##
This problem has one more question I have no idea how to answer:
How can scalar potential of this vector field with calculated ##p## and ##\alpha ## be written?
Pranav-Arora said:
Thanks CAF!
$$\vec r \cdot \nabla = (xe_x + ye_y + ze_z) \cdot \left\{e_x\frac{\partial}{\partial x} + e_y\frac{\partial}{\partial y} + e_z\frac{\partial}{\partial z} \right\}$$ Then doing the dot product gives $$x \frac{\partial}{\partial x} + y \frac{\partial}{\partial y} + z \frac{\partial}{\partial z}$$ which vanishes when acted on a constant vector. So I do not mean to say ##\vec r \cdot \nabla## vanishes identically.
Understood, thanks a lot! :smile:
I assume you mean finding \varphi from the definition
-\nabla \varphi = \vec A
I don't remember any elegant way of solving this besides solving three (or even less) integral equations like -\frac{\partial \varphi}{\partial x} = A_x \Rightarrow \varphi = \int dx A_x
Just be careful when performing an integration on x, for example, since its integration constant could very well be a function of y and z. Yeah, you'll have to do the other integrations as well.
Ok, I get it.
##\varphi=\int A_xdx+C(y,z)## now the idea is to find what ##C(y,z)## really is.
Will do that in my next post.
Given the supposition ##\vec A = \nabla \varphi##, you could find ##\varphi## by doing a line integral over an arbritary path between some reference point and some point in space. Analogous to the definition of potential energy in physics.
Ok,now second part.
##\vec{A}=[\vec{n}(\vec{r}\vec{n})-\alpha n^2\vec{r}]r^{-p}=[\vec{n}(\vec{r}\vec{n})-\frac{n^2}{3}\vec{r}]## if ##p=0## and ##\alpha = 1/3##.
##[\vec{n}(\vec{r}\vec{n})-\frac{n^2}{3}\vec{r}]=[n_x(xn_x+yn_y+zn_z)-\frac{n^2}{3}x,n_y(xn_x+yn_y+zn_z)-\frac{n^2}{3}y,n_z(xn_x+yn_y+zn_z)-\frac{n^2}{3}z]##
So ##U=\int A_xdx=\int (n_x(xn_x+yn_y+zn_z)-\frac{n^2}{3}x)dx=##
##=\int (n_x(xn_x+yn_y+zn_z)-\frac{n^2}{3}x)dx=\int (xn_x^2+yn_yn_x+zn_zn_x-\frac{n^2}{3}x)dx=##
##=n_x^2\frac{x^2}{2}+(yn_yn_x+zn_zn_x)x-\frac{n^2}{6}x^2+C(z,y)##
Now ##\frac{\partial U}{\partial y}=xn_yn_x+\frac{\partial }{\partial y}C(z,y)## which should be equal to ##A_y=n_y(xn_x+yn_y+zn_z)-\frac{n^2}{3}y## meaning that ##\frac{\partial }{\partial y}C(z,y)=yn_y^2+zn_zn_y-\frac{n^2}{3}y##.
Therefore ##C=yzn_yn_z+\frac{n^2}{2}z^2-\frac{n^2}{6}z^2+D(z)##
Now if you don't mind... I think you already got the idea how I calculated this so if you don't mind, I will just write what Is my final expression for ##U##
##U=n_x^2\frac{x^2}{2}+(yn_yn_x+zn_zn_x)x-\frac{n^2}{6}x^2+C(z,y)=##
##=n_x^2\frac{x^2}{2}+(yn_yn_x+zn_zn_x)x-\frac{n^2}{6}x^2+2zyn_zn_y-\frac{n^2}{6}(y^2+z^2)+\frac{n_y^2}{2}y ^2+\frac{n_z^2}{2}z^2=##
##=(yn_yn_x+zn_zn_x)x+2zyn_zn_y-\frac{n^2}{6}(x^2+y^2+z^2)+\frac 1 2 (x^2n_x^2+y^2n_y^2+z^2n_z^2)##
Hopefully..
