Mastering Vector Field Plotting: Homework Statement and Solution Attempt
To plot the vector field, vectors should be drawn at each point in the xy-plane, starting from the point and extending according to the function F(r). The length of the vector r is calculated as r = √(x² + y² + z²), which is essential for determining the direction and magnitude of F(r). For the point r = (2,1,0), the corresponding vector is F(r) = (2/√5, 1/√5, 0). A total of 24 vectors should be drawn, considering all combinations of m and n values from -2 to 2, excluding the case where both are zero. Clarification from the instructor is suggested for any uncertainties regarding the homework statement.
Ted123
[PLAIN]http://img84.imageshack.us/img84/5273/questionm.png
How do I go about plotting this?
At each point in the xy-plane, draw a vector with its tail on the point. For example, for the point r=(1,0,0), you have F(r)=(1,0,0), so you'd draw an arrow that starts at r and extends one unit horizontally to the right.
Does r = | \textbf{r}| = \sqrt{x^2+y^2+z^2} (i.e. the length of the vector)?
So for e.g. \textbf{r} = (2,1,0) does r=\sqrt{5} and so \textbf{F}(\textbf{r}) = (\frac{2}{\sqrt{5}} , \frac{1}{\sqrt{5}} , 0) ?
How many vectors are there to draw? (all the combinations of (m,n) such that m,n=0,\pm 1, \pm 2 )?
I'd assume that's what r means. You could always ask your instructor for clarification.
You should have 24 vectors to draw since m and n can each be one of five values, but you're omitting m=n=0.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
9K
