Finding the Angle Between a Vector in the yz-Plane and Another Vector
  • Thread starter Thread starter insan
    Plane Vector
The discussion revolves around finding the angle between two vectors, A = 3i + j - 2k and B = i - k, with a third vector C lying in the yz-plane that is perpendicular to A and has a magnitude of 7 units. The participants clarify the notation used for the vectors and derive the necessary equations using the dot product to establish the relationship between the vectors. The final calculation yields an angle of approximately 108.4 degrees between vectors B and C, confirming the solution's validity.
  • Understanding of vector notation and operations, specifically in three-dimensional space.
  • Knowledge of the dot product and its application in determining vector orthogonality.
  • Familiarity with trigonometric functions and their use in calculating angles between vectors.
  • Ability to manipulate algebraic expressions involving vectors and their components.
  • Study vector operations in three-dimensional space, focusing on dot and cross products.
  • Learn how to derive angles between vectors using the dot product formula.
  • Explore vector projections and their applications in physics and engineering.
  • Investigate the geometric interpretation of vectors in the yz-plane and their relationships with other vectors.
Students studying physics or mathematics, particularly those focusing on vector calculus, as well as educators and tutors seeking to clarify vector operations and their applications in real-world problems.
insan
Two vectors are given as A=3x+y-2z and B=x-z. A third vector C lying in the yz-plane is perpendicular to A and its magnitude is 7 units. Find the angle between C and B.
cross and dot product
I can't imagine of way, a vector lying on the yz plane can be perpendicular to a 3d vector which has 3 nonzero unit vector components. An explanation on this is much appreciated.
A vector in the "yz-plane" has the form <0, y, z>. Further, two vectors are perpendicular if and only if there dot product is 0. <a, b, c> will be perpendicular to <0, x, y> if and only if by+ cz= 0. For example, <a, z, -y> is perpendicular to <0, y, z>.
A = 3x+y-2z and B=x-z are numbers, not vectors! So, my first question is: what do you mean? Have you copied the questions exactly as they were given to you?
I'm not capable of writing exactly as they are given, they are vectors.
Then I am not capable of helping you.
I'm guessing they're something like this:
a = 3i + j - 2k
b = i - k
They could also be written like this:
a = <3, 1, -2>
b = <1, 0, -1>
yeah, i guess i couldn't think of writing it in that way. they were just meant to be x, y and z's with hats. i'll probably be more thoughtful next time.
HallsofIvy, I have found a result using dot product but what really bothered me with this question is not the solution but some things that i couldn't grasp in it. i will look into it tomorrow. thanks for your answer.
Ray Vickson, i hope you will be capable to help me with questions that are well written in the future.
Yes, no problem.
Even if you can't figure out how to write something symbolically, you can explain in words what you mean; for example, you could say that x stands for the unit vector along the x-axis, etc (but I would discourage that choice of notation, for reasons I won't go into here). Or, you could write e_x for the unit vector along the x-axis (making sure to explain your notation). Or, you could say that x really means <1,0,0>, where those are the three components of the vector. Or, you could forget about using x,y and z, and just write what they mean: <1,0,0>, <0,1,0> and <0,0,1>. There are lots of ways to do it; just not the way you tried!
I see now that I've had some misconceptions about the problem. I've tried to solve the problem but i am not sure about the result.
Vector A = 3i + j - 2k and vector C is perpendicular to it and it is also lying on the yz plane.
A.C = 0 = 3.Ci + 1.Cj -2.Ck Ci=0 since it is on they yz plane
Cj - 2.Ck= 0 Cj=2Ck
Vector C has the magnitude of 7:
C= 2Ck.j + Ck.k
7² = 49 = 4Ck² + Ck²
Ck = 7/**√5
C= 14/√5.j + 7/√5.k I need the angle between B and C.
B= i - k it is given. It has the magnitude of √2
B.C = 1.0 + 0. 14/√5 -1.7/√5 = √2.7.cosθ
-1/√10 = cosθ
arccos(-1/√10) = 108.4
Sorry for the messy math, do you think this is the answer?
Vector A is very clear, but it would be clearer if you wrote C in a similar form before you start working with it.
The components you give below for vector C are difficult to understand, as Ci could be interpreted as C * i and similarly for Cj and Ck. To make things clearer, let's define C this way:
C = c2j + c3k
I'm using the given information that this vector lies in the y-z plane.
Cj - 2.Ck= 0 Cj=2Ck
C= 2Ck.j + Ck.k
The notation above is awful. On the right side, it looks like C * k2.
insan said:
Ck = 7/**√5
? What does this (above) mean?
This is correct, but it's difficult to follow your reasoning, since you're leaving so much out, and your notation is so unclear.
1.0 and -1.7 appear to be the numbers 1.0, and -1.7, rather than the products 1 * 0 and -1 * 7. It's common practice to use * to indicate multiplication.
insan said:
-1/√10 = cosθ
What units for 108.4? Radians, degrees?
I've done some remediations on it; it should be clearer now.
Vector A= 3i + j - 2k
Vector C = C2j + C3k
A.C = 0 = 3*0 + 1*C2 - 2*C3
C2 - 2.C3= 0
C2=2C3
C= 2C3j + C3.k
Using the given magnitude of the vector C, which is 7.
7² = 49 = 4C32 +C32
C= 14/√5*j + 7/√5*k
B.C = 1*0 + 0*14/√5 -1*7/√5 = √2*7*cosθ
-1/√10 = cosθ
arccos(-1/√10) = 108.4°
Looks good. Thanks for making the extra effort to make it more readable!
  • · Replies 20 ·
  • · Replies 21 ·
