Undergrad Vector math (small angle approximation)
To determine that Θ = Δp/p, the discussion emphasizes the small angle approximation where sin(θ) ≈ θ for small angles measured in radians. This approximation is supported by the Taylor expansion of sin, which shows that higher-order terms become negligible for small θ. Participants highlight that even at θ = 0.1, the approximation remains effective. The conversation also encourages testing small values to understand the accuracy of the approximation better. Overall, the small angle approximation is a key concept for simplifying vector calculations in this context.
Boltzman Oscillation
Given the following vectors:
how can i determine that Θ = Δp/p ?
I can understand that p + Δp = p' but nothing arrives from this. Any help is welcome!
Mathematics news on Phys.org
Sin Φ ≈ ∅ for small angles.
(Different) Mentor edit: The above should be ##\sin(\theta) \approx \theta##, for ##\theta## in radians.
You meant to say that ##\sin\theta\approx \theta## for small angles.
wait wait what? How is this true? I've never known this!
Ah I guess I could see that being true since the taylor expansion of sin is theta - theta^3/3! +theta^5/5! so a small theta would cause the terms after the first to be significantly small.
Likes Delta2
To be clear, the angle is in radian measure.
You also see that from the fact that sin(0) = 0, sin'(0) = 1 and sin''(0) = 0. So sin is equivalent to the identity function up to the 2nd derivative around 0.
It's instructive to take ##\sin(\theta)## for some small values of ##\theta## (always in radians) to see just how good the approximation is. Even at ##\theta = 0.1##, which is a little larger than what we usually consider "small compared to 1", it's a pretty good approximation.
Likes PeroK and jedishrfu
Are you looking for more than just basic Trigonometry here?
Well the other gentlemen helped me understand better now but maybe you can provide more insight. So, yes.
okay i will try some small numbers. Thank you sir.
  • · Replies 25 ·
