Vector parametric equation of line
9 replies · 2K views
songoku
Let L be the line given by the equations x + y = 1 and x + 2y + z = 3. Write a vector parametric equation for L
Parametric equation:
##x=x_0 + ta##
##y=y_0+tb##
##z=z_0+tc##
I can imagine x + y = 1 to be line in xy - plane but how can x + 2y + z = 3 be a line, not a plane?
Thanks
songoku said:
Homework Statement: Let L be the line given by the equations x + y = 1 and x + 2y + z = 3. Write a vector parametric equation for L
Relevant Equations: Parametric equation:
##x=x_0 + ta##
##y=y_0+tb##
##z=z_0+tc##
Thanks
Neither is a line. They are both planes in ##\mathbb R^3##.
Two planes that are not parallel intersect each other in a line.
Ok so it means the question is wrong to call those two equations as lines. Basically the question gives two equations of plane and asks for intersection of the two planes.
I understand the question now. Thank you very much Orodruin
The question does not call those equations lines. The question specifies one line as the set of points satisfying both equations.
The points that satisfy both equations is a line. The problem statement is correct.
Suppose you set ##x=t,\ \ t \in \mathbb R##.
Then from the first equation, you have ##y=1-x = 1-t,\ \ t \in \mathbb R##.
Can you use the first equation to convert the second equation into an equation for ##z##?
Huh? I never claimed anything else. In fact, it is just a repetition of what I just said …
Sorry. Somehow I quoted the wrong post and didn't notice that I was responding to the wrong text. I must need more coffee. I'm going to fix that post.
##x=x_0 + ta##
##y=y_0+tb##
##z=z_0+tc##
Thanks
If you have two points on a line, then you can take one as the starting point, and the difference of two as the direction to travel along by the parameter. That gives you a natural parameterization.
It seemed I interpreted it too literally. "Let L be the line given by the equations x + y = 1 and x + 2y + z = 3" in my interpretation meant the given equation are lines, which is actually not what it means by the question.
Yes I can
Thank you very much Orodruin, FactChecker, fresh_42
Which is actually not what it means at all. The question talks about the line given by two expressions. You have simply misread the question.
