Vector Problem-Direction and Magnitude
6 replies · 5K views · last reply
baseballer10p
Determine the magnitude of the resultant force Fr=F1+F2 and its direction measured from the positive u axis.
Vector diagram with a common origin: u axis pointing right, v axis pointing up and to the left, F1 = 200 N at 30 degrees above u, F2 = 300 N at 50 degrees below u.
Law of Sines?
I drew parallel lines and attempted to use the sine law, but I got two different answers.
Here's the equations I used:
Fr/sin100 = 200/sin50
Fr/sin100 = 300/sin30
Vector diagram with axes labelled u and v, forces F1 = 200 N and F2 = 300 N drawn as sides of a parallelogram, with angles marked 30, 50 and 100 degrees.
Using these equations, I got two different answers for Fr, and didn't get any direction.Other than what I tried, I don't know what to do. We weren't taught how to find the magnitude from components or taught how to find direction.
  • Vector diagram with a common origin showing u axis pointing right and v axis pointing up-left, F1 = 200 N at 30 degrees above u, and F2 = 300 N at 50 degrees below u.
  • Diagram of two forces on a parallelogram with axes u and v: F1 = 200 N points up-right, F2 = 300 N points down-right, with angles of 30, 50 and 100 degrees marked.
can't see your images, can you link it instead?
I have to use the angles to figure out which direction the resultant force is pointing after [tex]F_1[/tex] and [tex]F_2[/tex] are added, but I don't know how.
The things you know for sure are the 200, 300 sides... and the 100 degrees angle. You can use those to get the magnitude of F1+F2, and the angles...
Draw a triangle separately from the axes... when you get the angles... then you can draw F1+F2 in correctly...
