Vector space and fields question
9 replies · 2K views · last reply
ilyas.h
Let V be a vector space over the field F. The constant, a, is in F and vectors x, y in V.
(a) Show that a(x - y) = ax - ay in V .
(b) If ax = 0_V show that a = 0_F or x = 0_V .
axiom 1: pv in V, if v in V and p in F.
axiom 2: v + v' in V if v, v' in V
(a) x - y = x + (-y)====> (x+ (-y)) in V (axiom 2)
====> a(x + (-y)) in V (axiom 1)(b)...?
how would I start part (b)?
How about starting by assuming that both a and x are different from their resoective zeros and trying to find a contradiction?
if they are both non-zero then they cannot bultiply together to give a zero vector i.e. either one (or both) have to be their zero's.
I feel as though I am missing something, my solution is too simple.
Yes, but why can they not multiply to zero if they are both non-zero? This is the entire question.
just looked up all the axioms from a Field and a vector space, from what I can see:
a Field doesn't have the multiplicative axiom: 0a = 0. On the other hand, a vector space does have this multiplicative axiom: 0v = 0.
ax =/= 0_F because that would assume that an element in the Field contains this specific multiplicative axiom.
ergo, ax = 0_V iff a = 0_F or x = 0_V
Note that, while not an axiom, it is trivial to show that this is true from the distributive property of multiplication.
I am not really sure what you are trying to argue here.
a in F. v in V. Let's refer to it as an axiom for the sake of simplicity.
since a is in the field, you cannot have 0a = 0, because this multiplicative axiom is not in any Field, given the axioms in a Field.
Therefore, ax =/= 0_F, because if x=0_V, then you have a0 = 0_F, and this is a contradiction (given the axioms in a Field).
Therefore, ax = 0_V, because a vector space can contain the axiom 0v = 0, and it holds when either a = 0_F or v = 0_V.
I could be wrong, or perhaps i didnt explain it properly.
As I mentioned, the relation 0a = 0 is true for all fields. You have that:
(b + 0)a = (b)a = ba
But at the same time, the distributive property gives
(b + 0)a = ba + 0a
Adding the additive inverse of ba to both these relations gives
ba + (-ba) = 0 = ba + 0a + (-ba) = 0a
And therefore 0a = 0.
(b + 0)a = ba + 0a
i misinterpreted your reply.
If that's the case, could we use the inverse?
assume a and x are non-zero's:
ax = 0_V
ax*a^-1 = 0_V * a^-1
x = 0_V
contradiction. x must equal 0_V.
on the other hand, there is no multiplicative inverse axiom within a vector subspace, therefore if
ax = 0_V
you CANNOT do:
ax*x^-1 = 0_V x^-1
i.e. you cannot eliminate the x on the LHS, ergo:
ax = 0_V (=/= 0_F), iff a = 0_F or x = 0_V
x = 0_V
This is sufficient. You do not need to worry about the existence or non-existence of a multiplicative inverse for V. You assumed the anti-hypothesis of what you wanted to prove, i.e., that both were non-zero, and arrived at a contradiction, thus proving that the anti-thesis is false, meaning that the hypothesis is true.
